Lookin' for rim for D14 near Kansas City
CarsonD14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CarsonD14 Quote  Post ReplyReply Direct Link To This Post Topic: Lookin' for rim for D14 near Kansas City
    Posted: 25 Oct 2011 at 9:58pm
Guys,
My rear rim finally rusted through.  It's the power adjust rim.  I'm looking for one to replace it.  If you have one you'll sell, drop me a message with the price.  Used is fine!  Just needs to be in good shape.  Also, if you know a good place to buy them from, I'd appreciate that info as well.  Thanks!
Carson
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 6:35am
check the vendors on this site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CarsonD14 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 9:27am
Yeah, I'm going to do check with the vendors, I just thought I'd try to find a local individual instead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 9:45am
Can you weld? It's not a all that hard to repair one if you can weld. I used a metal cutoff wheel in my Skil Saw to cut the rusted area out and replaced it with a section cut from another wheel. Mine turned out good enough if you don't know they were repaired, you'd never know it. The only giveaway is there isn't a hump next to the valve stem hole.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 10:14am
I have a couple. I come to the air port sometimes. 150 miles for KC. 785-353-2392
Post Options Post Options   Thanks (0) Thanks(0)   Quote CarsonD14 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 10:32am
Ray: How much would one be?  (I think you're the guy we bought a front spindle from recently).  Spindle seems to be fine now!
Brian: Thanks for the idea.  Dad's a good welder, so maybe we can give that a try.  We're going to be throwing it away if it doesn't work anyhow, so it's worth trying.  If we decide to do it, I might PM you.
Edited by CarsonD14 - 26 Oct 2011 at 3:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 2:42pm
No problem. It was as simple as slicing a big enough repair section from another wheel and tracing around it then slicing the bad section out and welding the new section in. That was a bunch cheaper than new wheels...
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 2:49pm
If you do decide to purchase new, I can recommend Tony Carbaugh who is a vendor on this site.  I purchased two new 12x24 rims from him a couple of years ago.  Good price and great service.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 7:38pm
  we have new 12x26 rims in stock   can also ship same   1-800-254-3116  from factory
  way cheaper
