190xt relif valve no longer avalible.
prospolaris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote prospolaris Quote  Post ReplyReply Direct Link To This Post Topic: 190xt relif valve no longer avalible.
    Posted: 24 Oct 2011 at 3:30pm
so as i mentioned on past post i bought a 190xt that would not steer. as taking the rear section off the pump the floe divider was stuck. well i thought i was goldin. not so easy. the previous owner took out the relif valve in the next port over thinking this would cure the issue. well eeeeeehe did away with it and parked the tractor after not working. so i went to the local agco dealer and the part is no longer avalible.AHHHH so now the only was i can get this little relif valve is to get a new or used pump. $950. great.......... this is where i ask you guys for some help. any one have one? or a used pump that u wouldnt mind selling me the releif valve out of? any help would be great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 8:51pm
I should have a used relief valve. Can check in the morning. MACK   660 828 4310
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 11:37pm
well...there was a 190 forsale in another post, it should have what you need and more!!
This page was generated in 0.138 seconds.
