I don't care if it's John Deere...
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: I don't care if it's John Deere...
    Posted: 24 Oct 2011 at 2:47pm
I want to see this beast in action
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 2:50pm
I would to!!
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 2:55pm
Most likely would pull a good sized load, even a plow!  I really would like to see it in action.
Edited by JoeO(CMO) - 24 Oct 2011 at 3:05pm
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 3:07pm
   Rather drive one of these :
http://www.rumelyallis.com
jccleav View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jccleav Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 3:20pm
What would you call that thing? I would hate to turn it around.
The joy is in the journey.
AC "B" and "WD" and "C"
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 3:32pm
As cool as it is, I wouldn't want the back unit to have better traction or more horses than the fronts, I see a wreck ahead it it did!  :-)
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 4:16pm
With hydraulic steering you'd blow a pump or cylinder before you'd bent the frame
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 4:51pm
I guess I wasn't talking about bending a frame, I was just thinking of folding that thing up, but your point would seem to hold true there as well, depending on how it was plumbed.  If both cylinders on one side are simply plumbed together with no restrictions, it would take very little to force the center tractor sideways, since one cylinder will extend while the other retracts, and ise versa on the other side.
Still in use:
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 5:02pm
3 engines at 80hp each, 240 hp on tap.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 5:27pm
I'm guessing it has some type of ball-valve to prevent this, atleast, I hope it does lol. It's claimed it will pull 40 ft of plows, in fifth gear but thats all I know about it
Quote Now here's what they call the ultimate 2-cylinder tractor - it's (3) 830's ganged together. Supposedly it'll pull 40ft of plows in 5th gear.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 5:58pm
That or some sort of pressure equalizer
German Shepherd dad
#WD234847
#WD88193
Francis/NorthernMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Francis/NorthernMN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 6:18pm
Nice unit!  It was built and is owned by Don Dufner of Buxton, ND.  Have seen it in action at the Rollag, MN show.  He built it in 1994 and it was his main tractor for several years on his 3000 acre farm.  Rear tractor has an engine shut off switch  to kill the engine in case it gets turned to short.  This takes care of jack knifing and  getting pushed around.  Don has built a lot of tandem and triple tractors in the last 50 years.  He will take time to talk to any one and share information.  I believe there are videos on You Tube of this tractor in action at the Rollag show.  I have some pictures from the 2008 Rollag show of Don plowing with the "830" Special but don't know how to post them.
Francis
Bemidji, MN
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 6:24pm
Folks that's the first ever JD 6cyl unless we count pony motors. That thing would sure be handy for backin a pair of wagons in the barn.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 6:40pm
from youtube, you'll have to cut and paste it
http://youtu.be/j2BAhrLIz_I
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
RickUP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickUP Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 6:54pm
How many mechanics,,, n parts stores do we need to keep it workin hard, not just crusin in a parade?? Ha Ha!
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 7:28pm
 That is  a lot of torque,   Big  field  tractor  Onley  !!   Tony
jhid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhid Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 8:18pm
here it is in action
[TUBE]JDb7RvPZhbs&feature=related[/TUBE]
red and green are nice for christmas, but orange is all year round
http://www.canadianantiquetractor.com/tractorforum/
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 8:31pm
I will bet the 4W305 will do more work on less fuel than that green thing.  MACK
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 8:38pm
That round cab with the 2 cylinder sound is messing with me :)
Thanks
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 8:53pm
If it takes 4 people to operate it it makes combining the tractors sortta useless doesn't it????
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 9:00pm
Thats how all of those plows were back when those plows were built. Nobody had hydraulics yet. Everything ran on steam.
German Shepherd dad
#WD234847
#WD88193
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 9:05pm
Even though I do appreciate the guy's ingenuity and hard work for building this thing I would still have to agree with Mack and RFDeere for all practical purposes. But it does make a great conversation piece.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 9:58pm
That it does! I may be somewhat bias, due to my soft spot of JD because grandpa restored a 43 B as my first puller, but  like I said, Deere or not, that thing is cool. and I'd love to see it in person.
Edited by AC WD45 - 24 Oct 2011 at 9:58pm
German Shepherd dad
#WD234847
#WD88193
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 10:02pm
The late JD 2 cylinder tractors set records for fuel economy. Forgotten in the new generation JD that tended to be hungry. Beat only in the last decade.
Gerald J.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 6:38am
The diesel 2cyl's maybe good on fuel but when my brother-in-laws 60 gas was broke down and he used my wd to farm that year with a 45 crank and overbore with big manifold and carb it still used about half the fuel as the deere. He couldn't believe it and I still rub it in 10 years later.
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 9:02am
The gas two-cylinders were not known for being good on fuel.........the two-cylinder diesels were. The 720 diesel held the fuel economy record for a long time after they didn't even make them anymore.
