local tractor club meeting
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: local tractor club meeting
    Posted: 20 Nov 2009 at 7:12am
Our local tractor club, "Iron Sharpens Iron", will be having a dinner meeting this Saturday nite at 6:00pm.The meeting will be at the Lawson, Mo. Baptist church south of town on 69 hiway. I will be doing a talk on the proper procedure of cleaning and lining a fuel tank. I will also hit a few high points on the paint end of restorations also. All welcome, come if you can.  David Maddux.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 8:25am
Too far to come hear the talk on fuel tank restoration. Would like to here it from someone who has lined one sucessfully. Maybe you can post some doos and don'ts from your experience here.
    I have a paint question for you Dave. Gary has primed everything but the sheet metal on his B with Valspar spray can red primer. The sheet metal will be sandblasted primed with PPG epoxy, body work done and then finished with The PPG AE system. Any problems you foresee comming with PPG AE over the red Alkyd primer or anything already painted with Alkyd Enamel.
   My CA is PPG AE over Alkyd enamel on everything but the sheetmetal and no problems yet. Conventional wisdom says this shouldn't work.    Ken
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 10:32am
The only problem I can see would be top coating too soon since the two components may not be compatible. If it has enough time for all of the solvents to evacuate, it may be alright. I would be afraid to try it, epoxy and top coat is too expensive to play with, not to mention the mess trying to correct a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 10:47am
The bodyman that I have do all of my painting whether on my cars or tractors, always say's "never mix anything" meaning mfr's paints. Always stay with what the mfr. tells you to use, and you'll never have a problem providing you apply it correctly. Especially as time progresses after the paint job was done....
Steve@B&B
