Engine Oil Qestion/Advice |
Post Reply ![]() |
Zyta ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: Ontario Points: 238 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Oct 2011 at 8:57pm |
Looking for advise....what oil would you use in a totally rebuilt 226. This engine is my 45 puller. 10w-30, 10w-40 or 15w-40? tractor is not used in the winter months. Should I be adding any additive that's avialable out there to help lubricate the cam and lifters?? is it zinc additive?
Jim
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 78817 |
I like a good 10 w- 30 oil . The 15-40 normally is special addatives for a diesel.. but is o.k. |
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Just don't use a synthetic oil until it's had a hundred or so hours on it.
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
yah, I am definitely staying away from synthetic until its well broken in. Have been using Quaker State 10w-30 but have herd about a zinc additive for cam and valve lubrication.
Jim
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7269 |
I have 10W30 in my rebuilt D14 with no problems. Doesn't see much action in the winter either.
Tricky Dickie ![]() Silver Level ![]() Joined: 05 Nov 2009 Location: North Yorkshire Points: 186 |
Zinc-based anti-wear additive is already included in the formulation of most good quality engine oils and further additives should be unneccessary.
Tricky Dickie
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4516 |
Jim, you are right to ask the question. There was a lot of discussion and premature cam failures in the aftermarket car performance world with flat tappet cams after the zinc was removed from the oil particularily with new rebuilds and cam breakins. All current automotive cams are rollers. I know Royal Purple oil was recomended. There may be additives now to solve that problem. I did stock up on the zinc oil but its almost used up now.
Brian Jasper co. Ia ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
I can think of 2 right off that are still flat tappet. Cadillac North Star and Chevy (Daewoo) Aveo.
Thanks Calvin, yes I am worried about the big block Fairlane and the AC's and heard about the additive. However if there's a brand of oil that will give me the required protection for the cam's in theses old engines it would be great to know.
Thanks,
Jim
Jeff Z. NY ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 7326 |
Yes. It will all be in PM I'm sending you tonight.
I had one question {Technical} that I am waiting on an answer to. I don't want to give you bad info. |
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Last I heard, diesel oils had the better flat tappet package because many diesels have flat tappets in the individual injection pumps with more load than valves. Also oils to older SAE ratings than the current on have more additive. You can check on the make up of oils by looking up their MSDS which lists percentages of contents.
I think zinc additives when passed out the exhaust mess up catalytic converters is why the latest oils have that minimized. Gerald J. |
Got my answer.
Sending you a pm. |
Post Reply ![]() |
