wc wiring
tmodeen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tmodeen Quote  Post ReplyReply Direct Link To This Post Topic: wc wiring
    Posted: 22 Oct 2011 at 10:27am
My grandpa passed away and left me his 1945 wc. He was rewiring the tractor then got sick and it didn't get finished. I would like to get it running again but I don't know much about wiring. I know it was converted to a 12 volt. Any help or suggestion would be very much appreciated.
    Thanks, Trent
Edited by tmodeen - 22 Oct 2011 at 11:16am
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 7:40am
bumped you to the top. Some one should answer:)
Edited by Josh Day - 23 Oct 2011 at 7:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 7:55am
You need to give more more information. Does it still have the magneto or does it have a distributor?  Is it the original generator and cut out relay with the 3 position switch?
 If it has a magneto, the only wiring you need to make it run is a battery cable to ground and a cable to the starter switch, and you don't need that if you crank it by hand or pull start it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 8:44am
We offer a 12V conversion system with Generator or Alternator, for Mag or Distributor. I can build the system to your Grandpa's tractor. Drop us a line if interested......
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 8:46am
Sorry, should have said for Generator or Alternator depending on which you have.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 9:36am
for 6 volt distributor set up.
This page was generated in 0.071 seconds.
