AC 170 3-point
toddc78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toddc78 Quote  Post ReplyReply Direct Link To This Post Topic: AC 170 3-point
    Posted: 21 Oct 2011 at 5:35pm
I have a 170 and it has been a nice outfit for the time I have owned it.  Just lately, the 3 point doesn't want to lower.  It comes up fast when I pull the lever back but doesn't do much when I push it forward.  It barely goes down and I just wind up putting the thing in float and it still doesn't go down too fast.  I have noticed that it seems to be making a hissing noise back by the remote.  Have any of you fellows ran into that before?
Thanks
prospolaris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote prospolaris Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 5:43pm
have the same problem with our d17 since it was new in 1966
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 5:47pm
Is it only with nothing attached to the 3 point or also when you have something attached to it.
1969 190XT series 3
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 5:47pm
If you don't have any weight on the 3pt, that's pretty normal.
Hurst
1979 Allis Chalmers 7000
5800 Hours
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 6:04pm
I have had that with my D17 IV.  The depth and, or traction buster linkage and valves were sticking.  Had to use bp blaster and free them up.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 6:36pm
Todd I have the same issues, so I just move the depth and tb levers back and forth a few times to the stops, then I lower the lift arm lever and if I stand on it they go down fine. But sometimes I have to as I say move the other 2 levers. Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote toddc78 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 6:59pm
I have a blade on the back and I remember it going down fine the last time it was on. This time it would barely move even when I was on the 3 point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toddc78 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 7:45pm
I also noticed that the thing actually went up very slowly once when I tried to put it down.  It used to flop the blade down pretty hard when I dropped it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 8:24pm
TB spool is stuck part way in. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote toddc78 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 8:41pm
Thanks Mack.  How does one go about fixing that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 11:32pm
There have been previous post on this in past,I will see if I can find it.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 12:09pm
The linkage to the traction booster is rusted up and is activating the valve.  Some penetrating oil on the linkage helps to free it up.  Although I use the more time consuming method of removing the bushing that the actuator pivots on - the bushing needs to be cleaned and soaked in anti seize compound.  It will work like new afterwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toddc78 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 8:46pm
Thanks gentlemen. Looks like the linkage came loose on the TB.
This page was generated in 0.073 seconds.
