7045 turn signal? |
Post Reply |
XT in pa
Orange Level Joined: 21 Apr 2011 Location: hickory pa Points: 711 |
Posted: 20 Oct 2011 at 9:59am |
With the 4-way flashers on and the turn switch on both ,4-ways flash,but when you turn the switch for the turn signal (right or left) they will not blink they just stay on. I checked the flasher but it works on the 4-ways and there is no bulb burnt out.
thanks Shawn
190XT,D17and 7045
Ben (MI)
Orange Level Joined: 02 Jun 2010 Location: SW Lower MI Points: 737 |
If I remember, I had the same problem on my 7000 and replacing the flasher unit did the trick. Not too expensive to try it anyway. Good luck.
niel ev
Silver Level Joined: 04 Feb 2010 Points: 189 |
Shawn the switch should be a square box right ? if so they may have replaced it with a later switch and if memory is working tehy had to cut one of the wires to got it to work but I don't remember which one I'll see if i can find out Niel
XT in pa
Niel when you talk switchwhat one do you mean i just changed the main light switch cause it was shorted out,anyway it had a circut braker on it the one for the turn signal i think is a big round switch the part under dash hope this helps .
Shawn
190XT,D17and 7045
niel ev
Shawn the main light switch should be square and in the new box there should have been an paper telling you what was changed or what wire needs to be cut had the same thing happen to us about 4 years ago Niel
niel ev
Shawn I forgot to ask if your tractor wasunder serial number 3053 I was working on a later tractor when we had that problem and also it was the turn switch not the main light switch Niel
SHAMELESS
Orange Level Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
i replaced one on my 7010, and there is one wire you leave disconnected, but can't remember which one, it tells you in the instructions....also may seem dumb, but check your bulbs too. even tho they work in one position, dunno why, but i replaced one bulb and it worked!! *scratching head!!!
XT in pa
sn 1115
190XT,D17and 7045
Eric[IL]
Orange Level Joined: 14 Sep 2009 Location: Illinois Points: 485 |
I just changed this in-dash electrical switch unit in my black 7060. Same problems you are mentioning. It took care of the problems. Yes, there is a installment paper in the new part box. Just follow directions.
XT in pa
Eric so you say its the turn signal switch.
Shawn
190XT,D17and 7045
Post Reply | |
