D17 Puller + Power Director
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: D17 Puller + Power Director
    Posted: 19 Oct 2011 at 9:49pm
I am going to build a V8 D17 puller this winter. Has anyone retained the PD with a higher hp application. It will be a mild big block Chev. I was also thinking of putting in a 3 speed auto and eliminating the PD. Trying to figure out if I want a long wheelbase with the auto trans configureation. There is a guy that pulls with us that has a Chev 350/ Allison auto out of a school bus in a 300 Farmall, and a 6 cyl
Ford mated to the torque tube on another 300 Farmall. The long tractor looks cool, but takes up precious space on the trailer.
Brian
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 6:06am
Take it out !!! V8 high rpm's may make it explode !!
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 6:29am
Putting a D-19 PD that has one more disc in high and low range will help a lot. I did that in my 175 with a turbo in it. DrAllis is right, do not make too many rpms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 7:25am
At 3000 rpms you may loose both legs. Could also loose 2 of something else.   MACK
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 7:59am
So what comes apart in the PD? Do the shims fly out or the keys on the little pins come off? Or housing split open?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 8:18am
Yes!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 9:11am
The PD is made of cast iron. The cast iron spinning around at Hi RPMs Will come apart(exploid). I would not want to turn one over 2800 at the most.
 Better to be safe than sorry.
  Have saw 190s explode when guys thought they could pull start them.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 9:56am
Thats to bad,it sure would be nice to have going against bigger cube tractors. I guess I didn't notice it's cast iron.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 11:13am
Pressure plate exploded in my 55 chevy one time,NASTY!!!
