Glass Replacement in Cab
Husker200 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Husker200 Quote  Post ReplyReply Direct Link To This Post Topic: Glass Replacement in Cab
    Posted: 19 Nov 2009 at 12:30pm
I need to replace the lower LH glass in the door of a AC cab on a 200 tractor.  Is there anything special about the glass that a local glass company could not reproduce?  If so, any links or contacts where I could find a replacement piece of glass?  I better do it before the snow flies.
Thank you.
Jerod
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2009 at 4:57pm
I wouldnt think it would be anything too special about it.  I've never had a piece of glass cut for anything, but may need to do it in the future for a couple 7xxx tractors that I have.  I'm sure that window you're looking for is just a piece of flat glass?  If so, it shouldn't be a big deal.  Just whether its tinted or smoked, or maybe tempered?  then just get the shape you need.  OR somebody may turn up with a used glass.  Tried any junkyards?  by the way..is it a factory cab?  because someone posted a link to Year-a-round and hiniker cab replacement parts a while back..     -Wes
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2009 at 5:12pm
It safety glass, two panes held together with a glue.  Same as a car windshield.  A glass shop should be able to cut one for you, the trick will be the curves at the corners.  If you make a template with cardboard and take it along, it shouldn't take too long to cut.  I watched a guy replacing them in a school bus once.  Neat stuff, you score one side and then flip it over and score the other side the snap it and then cut the glue at the break.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2009 at 5:22pm
There ya go.. Johns got the better answer!  lol
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2009 at 5:49pm
Eisenmann supply in Madison Nebraska has parted a 200 with a really good cab. The tractor had a loader on it and a vehicle struck the front part of the loader breaking the tractor right in the middle. Should have that glass piece still you can call them they would let ya know
Post Options Post Options   Thanks (0) Thanks(0)   Quote Husker200 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2009 at 8:23pm
I called Eisemann's this afternoon hoping they had one.  The door is already gone.  Hopefully they call back as I need some window brackets as well and they thought the cab still had those.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 5:00am
they have several cabs off of some 7000 series not sure if they would have the same brackets. Also strumps dump in Spalding had a couple of 200s junked not sure how their doors are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 9:45am
I used Lexine sheet, same thickness as glass, and cut my own window for rear of my 715B, the Lexine has held up well and been in almost 10 years now without scratching of discoloring. Also did one door window in same, just have to clean with wet cloth and not rub dry.
