allis d15 series II REAR TRED ADJUSTMENT
cobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Topic: allis d15 series II REAR TRED ADJUSTMENT
    Posted: 16 Oct 2011 at 3:45pm
HOH DO U ADJUST REAR TREAD WIDTH ON A D15 SERIES ii  IT DOE NOT HAVE POWER ASSIST IWAS TOLD IT HAS A SET SCREW ???  THANKS
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 8:49pm
It is does not have power adjust rims, the wheel tread cannot be adjusted.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 10:34pm
If the rims have different offset centers then you can swap sides.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 5:33am
Somebody replaced the original rims with combine rims I would guess. The rims might be offset so you can switch the rims to the other side. In order to adjust as original, you would need the PAW rims.
