Situations when using hand clutch on wd 45
frarob16 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frarob16 Quote  Post ReplyReply Direct Link To This Post Topic: Situations when using hand clutch on wd 45
    Posted: 15 Oct 2011 at 1:19pm
I posted this seperate so I didn't hijack AC WD45's post on jumpy hand clutch. Being a newbie, in what circumstances would you use the hand clutch? If I'm correct it disengages all power from engine to tranny and pto. I was under the impression that it allowed you to use the belt drive pulley and keep the tractor stationary without having the tranny in nuetral or run the risk of jumping into gear. Why would you use the hand clutch to shift gears instead of the foot clutch?
Another question, are you guys shifting on the fly or is that possible? I guess what I mean is say for example if I start off in 2nd gear can I shift to 3rd while moving by lowering the throttle and try to match rpms and gear mesh?
Thanks Guys
Butch
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 1:28pm
Originally posted by
<DIV>Another question, are you guys shifting on the fly or is that possible? I guess what I mean is say for example if I start off in 2nd gear can I shift to 3rd while moving by lowering the throttle and try to match rpms and gear mesh? </DIV>
<DIV> </DIV>
<DIV>Thanks Guys</DIV>
<DIV>Butch</DIV>[/QUOTE
Thanks Guys
Butch
[/QUOTE wrote:
Is it possible?  Yes.   Should you.  No.
The proper way to shift gears is to bring the tractor to a stop with the foot clutch and after the transmission is stopped you can then shift gears.
You may be able to shift on the go without grinding the gears but in the long run you will do much more harm for those times when you do grind them.  Not worth the risk IMHO.
Edited by Stan IL&TN - 15 Oct 2011 at 1:31pm
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 2:00pm
The hand clutch stops the tractor but not the pto allis  first version of live pto.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 2:18pm
Say you have reason to stop when using a piece of machinery. To do something to the combine or picker. You can spin up the machine to run whats in it through or just have it running when you begin forward movement. The tractor isn't under a strain when it gets back into unharvested grain.
Longmeadow Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Longmeadow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 3:23pm
I've owned and used AC tractors for many years..being 70 now. I had WD-45s and now own a couple of later ACs like a 175. I always used the hand clutch to shift. I was told by a AC mechanic many years ago that in order to save the collar shift transmission... by not wearing out the collars..and eventually jumping out of gear... disengage the hand clutch and pop the power director into neutral. I have many hard hours on the 175.. loader work, et al..  and have yet to have any transmission troubles... and I don't inadvertently grind the gears...and slip the dry engine clutch to start moving into a manure pile.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 4:02pm
I agree with all said about the hand clutch except the last comment.
One of the last factory schools I visited with Fred from Wertz Garage in Lineboro, MD the questions was raised about using the hand clutch or power director to shift.  We were told when starting from a dead stop to use the foot clutch unless you were powering up a PTO driven implement.  We were also told to bring the tractor to a dead stop before shifting - especially the constant mesh transmissions.  Shifting on the go and using the hand clutch had a tendency to round the ears on the gear splines that meshed with the collars.  The rounded splines caused the popping out of gear.
From reports on this site it is and has been a constant problem with Allis Chalmers Constant mesh transmissions - no pun intended.
I am delighted to hear that the gentlemen above has had excellent success shifting with the hand clutch.  I'm also sure that others have had a like success.
I'm just reporting what was relayed to us from a 1964 factory sales meeting.
Sorry I got so long winded.
Good Luck!
Bill Long
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 4:24pm
Just my opinion but I always engauge hand clutch when tractor is running and not moving, I have a 45 caravan tractor and always start out in 4th and just slip hand clutch to get moving, nothing conected to drawbar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Longmeadow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 4:38pm
I have forgotten one very important point. Many times you can't get the collars to line up or go into gear when shifting from one gear to another at a dead stop... , necessitating letting the foot clutch out a bit. If you are in a hurry and bring the foot clutch up too quickly you typically have a situation that may just grind the collars. By placing the power director in neutral allows the collars some free travel somehow and the shift can then be made without letting the foot clutch out a bit.  I never ... let me repeat..never grind gears/collars using my shifting method on my 175.  Step on the foot clutch..pop the power director into neutral..shift..let the foot clutch out engage the power director. I have 3700 hours on a mechanical tachometer, which by my calculation, based on my usual engine RPMs, is about 7000 hours. I have never had to adjust my power director clutch it remains as it was when delivered to us in January 1981. We check its adjustment every time the tractor is serviced...no adjustment necessary... all with the original facings.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 6:32pm
I use the hand clutch pretty much strickly when mowing from the time the pto is engaged till I shut it off. I wiil use it when I stop to open a gate as long as it's warmed up good.
It will creep otherwise.
Shifting is not a problem as long as your quick about it and fully disengage the hand clutch. It is for me anyhow. This is my second one and they were both the same.
The gears will bark at me once in a while. I have been doing it with this tractor regularily for 18 years and have had no problems.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 6:36pm
I usually use the power director to start the D-14-19 and WD-45 (hand clutch) off in 4th gear. Its an oil clutch and is smooth. I bush hog with a D-15 II and shift forward to reverse and back with the power director with no grinding of gears. You have to be quick!  I love taking off in 5th with the D-21 and double clutch my way up to eight'th.
Truck driving experience is a big help doing that and you got to get the rev's just right.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 6:46pm
If you don't use it bush hogging, the momentum of the bush hog will push the tractor forward if you use the foot clutch.
I commonly shift from 3rd to 4th while on the move, but throttle to 1/4 to 1/2 and use the foot clutch to "almost" stop, otherwise it's hard on the clutch
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 9:16pm
Anyone who's rode a WD or 45 much knows that the left foot goes on the lift arm shaft or step plate.Makes it real unhandy to use the foot cluch.Blade work and loader work take a lot of back and forth while raising and lowering "tool". Once things are warmed a little you can slip back and forth tween 2nd or 3rd to reverse and back by just snapping out the hand clutch. Straight cut or synchro-mesh.Dad bought the WD new in 49 and it's been run that way till present.I've shifted my 45 that way since 1980 when I bought it.No "problems" from either.I agree in a perfect world you should stop and shift but I don't live in that world.Rolling up shifting and downshifting are part of my world too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 11:22pm
To get back to the original question, using a Roto-Baler would be one. You have to stop moving when it wraps a bale, but you need the PTO to keep running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 7:35am
Just using it with any baler. You get clumps that you need to slowly feed into the baler. Hence, using the hand clutch allows you to stop the forward momentum while the PTO continues to turn. One thing to mention: NEVER, but NEVER get off the tractor until the PTO has COMPLETELY stopped turning. I know too many people around my area who are missing limbs because they didn't do this, or worked on the equipment while it was turning. DON'T do this.  Just my 2¢ worth...
Post Options Post Options   Thanks (0) Thanks(0)   Quote frarob16 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 10:09am
Thank you all for the many replies. Most of the time the tractor will be used with a brush hog. I saw one replie stating to use the hand clutch to stop forward movement when stopping instead of foot clutch when using a brush hog. That was gonna be one of my next questions. Thank you. I have a greater understanding of situations when to use the hand clutch thanks to you guys. Once I get the motor running real good and can confirm that, I will spend the money to change the other fluids and some other worn parts. I have been driving it around on our little plot between adjustments and never actually tried using the hand clutch except when I have it parked and running to adjust timing and carb. It has been alot of fun. At the end of the month hopefully I will get the money to change manifold gaskets, muffler and batt box.
Once Again Thanks to All
Butch
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 10:21am
I used the hand clutch on my WD45 alot just yesterday morning mowing some of the fields.......if for some reason you want to get off the tractor without stopping pto (maybe something on the equipment needs to be checked with it running) You can lock the brakes and get off of the tractor from the front. I don't advise it but there is times when I think a piece of equipment needs to be watched other than from the driver's seat to make sure its working correctly. There are people that make steps for the front that make it even easier than getting on from the back I think.
A little off topic but you said you would be mowing mostly...I have a Lilliston Rotary Cutter with a hydraulic cylinder on it. If a small log all a suden pops up that you didnt see when checking the field the first time you can hit the hydraulic lever to raise the mower to go over it. Then you can go back and find it after the field is mowed and move it....makes it alot easier than a manual lift drag behind.
Edited by 79fordblake - 16 Oct 2011 at 10:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 11:51am
I was taught to only use foot clutch for shifting gears.The hand clutch is handy in being able to slow or stop while PTO is spinning.Keeps bush hog from pushing you forward(if mower does not have overunning clutch).Also can slow tractor if mower,baler,combine,snowblower,etc.etc,,gets bogged down.
Was very handy when I was younger.I could pull the hay wagon and stop with the hand clutch(could not reach foot clutch).Got me involved when I was too little to move bales.We used the hand clutch (Power Director) a lot on the farm.
Today I always put power director in nuetral,shift gear and then engage power director to start movement.Mainly out of habit and love to pull that handle back.Should always engage PTO with hand clutch in nuetral position.Then start movement of tractor after PTO has reached proper speed.I feel this is easier on the tractor than letting foot clutch and engaging PTO at the same time.
I feel the hand clutch / power director was one of Allis Chalmers best innovations and set them apart from everyone else.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 6:06pm
Most of the time we used the hand clutch for shifting when doing loader work with a WD (curved gear shift) going forward in 3 rd gear then reverse. By using the hand clutch the loader continues to lift while changing direction.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 6:47pm
The hand clutch is great when driving in parades.
are genuine." - Mark Twain
SC Dan K. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SC Dan K. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 7:23pm
My uncle had an early W D with the straight shift lever. He told everyone to use both clutches to shift the transmission. Always use hand clutch first and last. Never heard the transmission make a grinding noise that way. Otherwise I've heard him holler across the field grind a pound while you are at it. You don't want to hear that, but once!
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 1:47am
I use the hand clutch when baling straw, tractor speed is a little too fast at times so I use the hand clutch to slow the tractor down some, but keep forward movement, when feeder has caught up then I pull hand clutch back and continue baling at normal pace. Another thing I do before I engage the PTO is to lower RPMs and then let foot clutch out slowly so I don't break anything,  then run the throttle up, then pull back on the hand clutch and away I go..
been there done that, not doing it again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote frarob16 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 11:54am
So I'm guessing that you are "feathering" the hand clutch or are you letting the rotational mass of your bailer keeping you moving slightly forward and you have the hand clutch fully disengaged?
Another question to anybody caring to respond. When i swap out battery boxes I will take inspection cover off just to look at things especially the quality of oil. I've read in previous posts that some have good luck with hytrans or 80/90. When I do change oil I assume that I,m changing power diverter, transmission and rear end for a total of 17 gal. Would that be correct? Any recommended oils to use?
 I mentioned above on this post but I still wonder which allows me to slip or "feather" the tractor into motion say for example starting in 3rd or 4th gear without any attachments? Foot clutch seems on or off no matter how hard I try. So does the hand clutch have a smother action?
Thanks
Butch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 12:52pm
Butch, I would be feathering it. If hand clutch is disengaged all the way tractor won't move. Befor I go on, everybody on here will tell you that when cold you can have hand clutch disengaged and foot clutch ingaged the tractor will move due to the cold  fluid. Now when I bale in the heavy straw I would pull back on the hand clutch till the tractor starts to move and then feather it allong so not to jam-up the feeder.
  Your foot clutch might need adjustment and yes hand clutch has real smooth action, if in 3rd or 4th gear you can slowly let out hand clutch for a smooth take off....
  I use 80/90 in trans and rearend and hydraulic in hydraulic pump  HTH  John
Post Options Post Options   Thanks (0) Thanks(0)   Quote frarob16 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 1:25pm
I have learned alot, thanks to you guys. I need to hook up and move the brush hog and get it set up for winter. I'm going to try these techniques, but I now know what I need to do. At the end of the month I can really jump on this and get things done. It's been alot of fun and this forum has given me a wealth of information.
Thank you
Butch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 8:44pm
It takes a lot of 80/90 wt. to fill trans,rear end but I do not believe it takes 17 gallons.It calls for 17 quarts. 3 different places to fill.All go to same place but faster to fill through seperate holes.3 plugs along left side of tractor while sitting on it.Takes a while for oil to work its way through to all sections of tranny/rear end.
Hand clutch is designed to feather to slow ground speed down or stop completely.Not like a typical clutch that is designed to only work all the way in or all the way out.
Edited by Pat the Plumber CIL - 17 Oct 2011 at 8:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 11:55pm
Whoa Pat!! Only 2 fill plugs on left for trans/rear end.The 3rd one up front is for hydraulics.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2011 at 4:42am
The only thing I use the hand clutch or power director for is shifting gears. Then start off with the hand clutch or power director.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote frarob16 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2011 at 10:08am
Heck, I just saw that I said 17 gallons LOL!
Butch
