Is it a D-14,D-15, or D-17
Goat farmer n Ky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goat farmer n Ky Quote  Post ReplyReply Direct Link To This Post Topic: Is it a D-14,D-15, or D-17
    Posted: 13 Oct 2011 at 8:36pm
OK I'm brand new,Looking for help. I bought an AC from a family that their father had just passed away. they knew nothing about tractor....So here goes It's 4-cly. gas.4-speed with hi n lo on right side lever, has 3-point hitch, PTO.wide front end. has front end loader.Rear tires are 28's(by data page it's D-17) Has curved gear from left side of trans.(not D-17)...#s on front of trans. housing left side,down near floor board say's 63287A....this would jive for a D-17 but not for a D-14 or D-15(which has curved gear shift...have been told D-17 has straight shift lever located in center in front of seat) ..tractor has 1 rear hyd. remote in rear under seat..also has traction boost...I think that's what it is called......It's been painted with barn red paint and I can't find any emblems under the paint...OK what Have I got???...........Dave
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 8:42pm
The serial number is on the left side on the torque tube where the engine bolts in. You may have to scrape the paint. It will tell you the tractor model and serial number which we can then give you the year of the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 8:43pm
Never seen a D-17 with a curved shifter.D-14 or 15 would be my guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goat farmer n Ky Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 8:49pm
Calvin I found the numbers ,where the tractor bolts together(just in front of the shift pattern,left sidedown near the floor board...the numbers were stamped into the flange of rear section......the number is to large for a 14 or 15 , but a 17 doesn't have a curved gear shift.....am I looking in the wrong Place....
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 8:59pm
First off, WELCOME to the Allis Discussion board. There is a wealth of knowledge on here.
Look at the rear of the engine on the left side, between the carb and the fuel filter bowl.
 The serial # will be stamped into the flange of the torque tube. Like Calvin said, you might have to scrape paint to see them. On my D15 it would be above where the clutch rod goes into the torque tube and a little toward the front. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goat farmer n Ky Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 9:05pm
Thanks Bob, for the welcome and the "correct" location...first thing tomorrow I should have my answer........Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 9:19pm
Here is where the serial number should be.   Should start with d14, d15, or d17 then a space and a the serial numbers will follow.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2011 at 7:22am
            I wonder if you have a 170?
                      John Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goat farmer n Ky Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2011 at 10:15am
Found the numbers...couldn't quite make out the D but it is a 14..1958 model...kinda disapointed...hoping for more HP...but it runs good every thing works PS,PTO.3-point hitch,front end loader and 3 new tires.....but needs paint and decals ..been changed to 12Volt (GM Alt. & batt. I'm sure starter is still 6 volt )...Paid $2,000.....Hope it will lift 4x5 bales....has 2-way power on bucket...I don't think I got hurt.....Thanks for the help...Dave
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2011 at 10:19am
Sounds like a good deal to me.  You might have to put something heavy on the 3 point to keep traction on the rear wheels.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goat farmer n Ky Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2011 at 10:26am
Raer's are not loaded..but have hay spear for rear and on bucket....so I think I'm OK there....this loader looks like part of the frame holds fluid also..is this common?
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2011 at 4:53pm
The tractor's hydraulics have high pressure/low volume system so the rear lift doesn't work a loader like a more modern tractor would. So, it's common to use a loader with a front mounted engine driven pump to get good hydraulics for a loader. Also due to the front mounted pump it's common for the loader frame to be the reservoir for the loader.
