gasket tear in carb. cause sputtering?
troy(el paso, il) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Topic: gasket tear in carb. cause sputtering?
    Posted: 12 Oct 2011 at 11:12am
Hello All-
I think I know the answer to this one already, but I wanted to check with the experts.  I took apart my carburetor on my WD45 yesterday to clean it and noticed a small tear in the gasket that goes between the fuel bowl and the upper portion of the carb.  Would a small tear there be enough to cause sputtering at idle?  Thanks....
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 11:39am
Lets in air changes the mixture. Had one in a Ford car once that whistled a different pitch according to the throttle setting. Couldn't find one so made one of a cereal box and it worked fine for years.
If you make your own pay attention to the small passages that have to have a clearance hole in the gasket.
Gerald J.
Soilguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Soilguy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 4:14pm
I suspect it sure could. Might be more noticeable at higher aspriation rates, that is, higher rpms. You might...just a suggestion...check the timing. My D-14 runs great, but had a little puffing miss that went away under load. I moved the distributor just a tad, and that was the end of the miss. Good luck. Larry
