8070 fuel leak
Dwayne TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Topic: 8070 fuel leak
    Posted: 12 Oct 2011 at 10:35am
Noticed a small leak on #1 inj line.  The parts breakdown shows several pieces - dust shield, hold-down washer, nozzle & holder assy, and sleeve/nut assy.
Where is the most likely cause of the leak?  It's not much more than a seep right now.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 11:43am
most likely line itself cracked.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 11:55am
Could one braze injector lines?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 12:01pm
wont last very long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 4:34pm
It looks like the leak is below the sleeve and nut on the nozzle/holder
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 9:13pm
have the injectors been "rebuilt" recently? I have seen several times where someone attempts to rebuild the Bosch/American Bosch injectors, and they don't lap the mated surfaces correctly or at all. The holder will leak fuel, and it will look like fuel is coming out of the injector hole in the head. If line is leaking under the ferrule you can cut line off at the crack, and use a new ferrule, but the bend at the nozzle end is pretty tight. Good luck, Ed.
This page was generated in 0.069 seconds.
