B rear axle swap question
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Topic: B rear axle swap question
    Posted: 11 Oct 2011 at 9:21pm
My B has a single big nut rear axle.  What do I need to do to swap it for a five bolt axle?  I have a donor B with 5 bolt axle, do I swap the entire final drive assembly?
Andrew
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2011 at 9:52pm
That is the best way to do it as far as I'm concerned. I've tried just swapping the axels & that was a BAD plan! Kip
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2011 at 9:53pm
The easy way and probably the best way to get where you want to go is swap the complete finals.
Another method is finding a good set of 5 stud wheel adapter splined hubs B part number 210318 and use them with the 5 hole B reversable wheels part number 210105.
The adapter hub replaces the splined wheel center and you use the same big nut and washer.
The bolt circle is the same as the B flanged axle used with the reversable deep dish B/C wheel Part number 210214
The reason Bs had the 3 wheel options was to allow a wide range of rear tread widths from 40 inches up to 68 inches
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2011 at 11:05pm
Is the C 5 bolt centers the same as the B 5 bolt centers?  As I have some C inner wheel weights that I would like to use when I do the swap?
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 8:22am
I've got a B with the 5 bolt rears and adjustable WFE. It has the C weights on the inside rear wheels. Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 11:27pm
Mike;
  Pretty much the same thing I'm doing, swapped the arch for a adjustable front end already, and now came across a B with 5 bolt rears and I already have the C inner wheel weights, and more options at rims widths with the conversion is a plus.
Andrew
This page was generated in 0.089 seconds.
