WD 4x4
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Topic: WD 4x4
    Posted: 09 Oct 2011 at 12:07pm
WD FWA with recent paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 12:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 12:18pm
WOW... you got a story to go with the photos ? Type of axle, how does it drive,how does it work and steer, O.K.?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 12:37pm
Looks pretty cool. Is it a military front? How do you match gearing to ground speed from front to rear? Is it driven by the PTO?
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 12:46pm
Well, I see the PTO shaft for the front axle. Noticed that there are also two transminssions, how does that work? How about the IH rear weights?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 12:47pm
Looks like PS and there's a drive shaft coming from the rear area, assume pto.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 12:56pm
There is no PTO housing though, So I'm guessing one of the two tranny's drives the front, ant the other drives the rear. It probably has a differential from a WD in the front end, with some type of gear reduction somewhere, similar to the "double tractors" of the 60's
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 12:57pm
Now that I look at it, it looks like it has a WC tranny for the rear, and the WD tranny runs the front
German Shepherd dad
#WD234847
#WD88193
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 2:59pm
There were posts on this this winter. The front axle is from a 6000 series JD. I believe one tranny drives each axle. No hand clutch anymore.  Added on hydraulics
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 4:43pm
I'm surprised that 35hp will even turn both axles.
German Shepherd dad
#WD234847
#WD88193
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 5:16pm
That is SHARP!  Purdy even!
Greg Kroeker
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 5:38pm
they did a ton of work on that one, and a very nice job it looks like!!
G226WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote G226WD Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 10:10pm
Dutchboy Johan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchboy Johan Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2011 at 7:22am
Wow, what a conversion. How does it handle the 4wd?
---> Better by Design <---
Johan Straver, Almkerk/ Netherlands
Allis-Chalmers 190XT Ser.III #26829XTD
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2011 at 8:11am
Look closely, that is no WD engine, that looks like a D17 motor, probably built as well, so maybe 60ish horse???
Still in use:
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2011 at 10:27pm
D17(full flow) or E Gleaner block with WD45 front cover and distributor
Edited by Steve M C/IL - 11 Oct 2011 at 10:28pm
