SFW D15; S1 - SII w/ PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Topic: SFW D15; S1 - SII w/ PS
    Posted: 09 Oct 2011 at 8:39am
May have found a SFW Series One D15 and would like to know if this would bolt up to my SII SC tractor with power steering?
Have not viewed the Series One SFW as yet and it is about a 3-1/2 hour drive away.
Also do not know if this non running Series one has power steering.
Would the bolster be typical?
If I recall, the PS can be added to the tractors without PS as the bolster is the same?
Appreciate any input.
Thanks
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 8:55am
Yes it can be changed without removing the bolster, series I same as II
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 9:33am
Thanks; will it work on my PS tractor, if the SFW tractor did not havs PS?
Sounds like it will bolt up, but will my PS work?
Thanks
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 2:47pm
Power steering is in the bolster. All that stays on the tractor. Unbolt the pivot under the bolster and drop the WFE along with the rear pivot. Remove the WFE crank arm for the tie rods. The SFW pedestal will bolt right up to the bolster with more bolts than the pivot  used.
This page was generated in 0.056 seconds.
