help on D14 leak around belt pulley cover
troy(el paso, il) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Topic: help on D14 leak around belt pulley cover
    Posted: 17 Nov 2009 at 8:19pm
Hello All-
It appears that I have a hydraulic leak? that is coming from the belt pully cover on my D14.  I have never taken the cover off, so I don't know what to look for, but it appears from the manual that the hydraulic pump is located lower? than the belt pulley so I don't think the pump is leaking.  Any ideas?.......What should I look for when take off the belt pulley cover?......Thanks in advance.......Troy
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2009 at 9:42pm
it just could be the seal on the cover that is leaking
