D17 water pump |
alc609
Topic: D17 water pumpPosted: 03 Oct 2011 at 5:44pm |
Got my d17 out today to get ready to rake hay and noticed a noise in the front , maybe water pump. Can you grease them or do you need to rebuild them?
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 03 Oct 2011 at 9:27pm |
They are sealed bearings, and you can rebuild them, but it is almost not worth it, if you do rebuild them, you need to be very careful about getting it right. I would make sure it is not something else, run it for a few moments with the fan belt off.
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
alc609
Posted: 03 Oct 2011 at 9:53pm |
Has a bearing sound to it but don't do it at low rpm's only other could be alternator or pump
