D14 on 3 cylinders
tlokimer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tlokimer Quote  Post ReplyReply Direct Link To This Post Topic: D14 on 3 cylinders
    Posted: 02 Oct 2011 at 12:26pm
Hello!  I just joined this forum...   I think I used it years ago. I just purchased a partially restored D14, which almost runs good. After a day or two of playing with it, I finally pulled the #4 spark plug wire while it was running, and it sounded the same: as if it was running on 3 cylinders. Compression check of #s 4 and 3 cylinder were 125#. After switching plugs, wires, etc, I pulled the valve cover, and the #4 exhaust valve spring is weakened to the point I can push the valve down 1/2 way with my thumb, something I can't do with any of the other valves. Lash was still about .015" as th IT book says. The spring itself is deformed, some coils closer than others. Is this causing the #4 cylinder not to fire? It has good spark (using the old screwdriver in the plug wire to block test) and good compression. Is the loose spring allowing blowby not detected by the compression test?
  I grew up with a WD45 on a ranch, rebuilt that engine a couple times, plus some V-8s, Volkswagens, transmissions-  but that was years ago. This D14 needs some more of that, but I thought I'd throw this out. I think the head has to come off to get the best look...
Thanks!Tom
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 8:51pm
A broken or weak valve spring would definetely cause a misfire. I don't know how you could get a good compression reading with it that way. You can get an adapter to screw into the spark plug hole and attach an air hose to pressurize the cylinder so you can pull the spring off and replace it  withou removing the head. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 8:53pm
OH!! I sorry, WELCOME to the forum. Bob
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 9:01pm
I agree with bob, that the compressed air is the way to go, just make sure you don't over preassure the cylinder, and the engine will rotate.  Make sure the ignition is off, and what I do it lock the brakes, block the tires really well, and put it is high gear, with the affected piston at TDC, so if the seal is broken and the vavle drops, it will not drop into the cylinder and then you have to remove the head.
Probably what is happening to cause good numbers on the test, is the engine is moving at a much slower speed than when it is running, allowing the valve to seat in about the time needed, when running on the other hand it's just not getting closed fast enough.  I will be this is the problem, replace the spring and try it out.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 11:04pm
You can take the plugs out of all the cylinders, unhook the battery, use a small rope and push it into the affected cylinder. Leave plenty sticking out. Turn engine over by hand untill the rope holds engine from turning. Valves will be held in place this way. The most important thing at the point, is don't break the rocker arm supports.It is best to relieve the pressure from each rocker arm at this point. Some will  say you can just loosen the supports and re tighten only them. Might get by with that, might not. The supports are expensive to replace. Take your time and replace spring. The keepers are a pain without help or a valve spring compressor. Adjust all the valves after replacing spring. Buy the cork gasket, rubber ones will leak sooner. Enjoy your tractor. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote tlokimer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2011 at 1:21pm
Thanks! Everybody.... I'm on phone answering 'cause my Internet service is down. I'll try your ideas with all due caution. I've ordered a valve spring and head gasket. Will try to change the spring without pulling the head, with your good ideas, and keep you posted. Winter's coming & I hope get a loader fitted. Last year here was tough. Thanks again!!!   Tom
