Allis Hub for Bosch "A" Pump Needed
Smokey Joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Topic: Allis Hub for Bosch "A" Pump Needed
    Posted: 29 Sep 2011 at 9:56pm
Need a hub for an A Pump getting rid of the AMBAC on our 8070 AC installing an A Pump. Does Max Simpson still make hubs?
210,220,7010 AC,7020 AC,7040 AC,7045 Pedal Tractor, 8050& 8070 and Parts and Pieces of Many More!!!
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2011 at 9:31am
Only place I know that makes the drive hub and adapter and the lines is the Reliance works.You are aware that you have to open up the front of the engine to change it arent you? It isnt possible to just change the pumps.
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2011 at 2:26pm
ask around on the pulling forums, there are some floating around out there
