ac ca puller
fbac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fbac Quote  Post ReplyReply Direct Link To This Post Topic: ac ca puller
    Posted: 16 Nov 2009 at 6:14pm
Looking for someone that can tell me if 149g out of d15 will work in ac ca without much changing.Also if anyone has one like this already set up to pull for sale.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 6:58pm
  SHOULD FIT WITH NO PROBLEMS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 6:58pm
If anybody knows, it's Dick L. Seems like he stuck the internals from a D15 engine inside the original block a while back.
Jamie NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 9:41pm
Yes the 149 will fit. The 4 bolts that hold the pestal on the CA engine is 1/2" and the 149 is 5/8" so you will need special studs or drill the holes out on the pestal to fit 5/8" bolts. Use the CA flywheel and clutch. Top water hose will have to be a sharp 90 deg. bend to work or you will have make a custom water neck to use the temp gauge.I thank that is about it. I have CA with a 149 stroker in been pulling for 8 or 9 years now.
Jamie NC
Allis tractor puller CA WC WD D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 9:46pm
Here is a pics of mine.
fbac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fbac Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 10:09pm
Jamie nice lookig tractor.Can you give me specks on engine  and tire size that works best for you? Did you have to do anthing speical to rear end or stock ca gears? How much hp do you think you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 10:24pm
Those tires are 13.6-28 ,tire rule here in NC states no larger than 13.6 in 2700 to 3700 lbs classes. This tractor makes 45 hp on the pto at stock RPM. Will put 2 nd gear at all pulls around here at 3.5 with power to spare, 3 nd gear if the speed limit is 6 or higher on a dry hard track.I also have a D10 that has 36" rubber on it and has a few more ponys under the hood. I will help with motor spec by PM or phone call.
Jamie
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2009 at 9:38am
If you use the CA stepped studs it is not nessacery to drill out the front casting. The CA blocks were drilled and taped to 5/8"
fbac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fbac Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2009 at 2:46pm
Jamie my number is 515-577-5479 thanks.
fbac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fbac Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2009 at 2:52pm
Dick do you have a ac ca built to pull?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2009 at 3:37pm
No! I have not pulled for five years and probably will not pull again. I thought for over ten years that I had to pull two or more tractors most summer weekends. Lack of funds put a stop to it. I stroked a B and C for pulling and pulled Oliver 66,77 and 88 as well as a Farmall C. Those were just well running, slightly over spec stock tractors.
I still have two CA tractors that need to be rebuilt. I will not build them for pullers.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2009 at 7:23am
Sweet looking CA.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2009 at 2:03pm
Not any more work to install the 160 cid version out of the later D15 or off a power unit! Kip
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2009 at 4:04pm
good luck finding a 160 engine
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2009 at 6:57pm
Have a 160 engine from a D15II hi crop available. Ia 563 652-2949
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2009 at 10:01pm
I have 4  160,s  3 complete  from tractors and 1 from a forklift less carb and oil pump and filter adapter.They can be found if you keep looking.
PS fbac when is the best time to call ya.
Thanks Jamie
Edited by Jamie NC - 18 Nov 2009 at 10:03pm
fbac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fbac Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2009 at 10:05am
JAMIE GIVE ME A CALL ANYTIME BETWEEN 8AM AND10PM.
