1956 wd45
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: 1956 wd45
    Posted: 27 Sep 2011 at 6:18pm
what is the best or easiest way too remove the front crankshaft seal on the 226 engine without removing the timing cover with the engine still in the tractor? fan belt pully is off.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 7:42pm
 SHOULD NOT COME OUT HARD???  WITH A SEAL PULLER[SMALL ONE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 7:45pm
Frequently I change seals where the shaft is still in place. I find it works well to drill small holes in the seal, thread a long sheet metal screw in the holes, and grip the screw with a pair of side cutters. This works well when you have limited space in front of the shaft. Problem is driving the new seal in. Late model stuff usually has an installer that screws in the end of the shaft. You're going to need space for a hammer and driver. I would say either pull the cover off the engine, or remove the front bolster.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 9:00pm
      Ask Ryan Renko !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 10:39pm
Jim,
I hope you can get it done! I would like to see you do it, I could use some learning!
Mike Townsley
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2011 at 6:30am
The one on my 17 is leaking also, drat....
Charlie
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2011 at 10:32pm
Go to your local fru-frooo hobby-type store, and find a 'latchhook' tool.  Take the little flippy-thing off (just the hook on a handle), drill and grab the holes with that... couple'a tugs and it'll come out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2011 at 8:11am
Seals wear out but often go bad for other reasons.  A groove in the crankshaft could  cause leakage and would need a speedy sleeve to repair. The front cover may not be lined up with the crankshaft. That is normally done with a slip fit bushing that slides over the crank and into the seal bore.
