WC govenor ?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: WC govenor ?
    Posted: 26 Sep 2011 at 8:44am
I put a starter tank on my unstyled WC and plumbed it. The next time we started it it ran wild. I assumed it threw a govenor weight.
I pulled the mag & govenor assembley off and everything looked fine. I put it back together and started it and seemed to be fine. The next time we started it, it took off again.
I did not take the carb off and the carb inlet is shared by both tanks so I cant see how that would have changed anything. I believe the govenor issue is seperate from adding the starter tank.
The wieghts and bearing are different from the distributer drives I'm used to working on (D17 & WD45) so I'm sure I'm missing something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 10:47pm
bump
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2011 at 5:40am
Double check your fuel line position. It may be up against and restricting the throttle rod movement causing the symptom you describe.
This page was generated in 0.262 seconds.
