Why ?...
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Topic: Why ?...
    Posted: 22 Sep 2011 at 2:24pm
http://www.rumelyallis.com
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 3:05pm
Should be a Diesel now...
Charlie
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 3:25pm
On the one hand we can say that we have seen worse...but I agree, Why..........
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 4:31pm
isnt that an rc not a wc
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 5:13pm
Nope, its WC sheet metal, just moved back, must have shortened the drive train up somewhere.  Seen a stock WC with the tube and shaft shortened between the tranny and rear end.  Not fond of the way it looks.
Doug northern IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug  northern IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 6:13pm
why is right.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 6:41pm
Totally useless......
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 6:54pm
Well you start with a wrecked Mercedes and a junk WC and add to much time and money, and viola! It was a "project" and I'm sure it seemed like a good idea at the time.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 6:59pm
THE HORROR!! THE HORROR!!!!
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 8:24pm
The "Mersadies" engine just gives it more class!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 9:40pm
Uhm...
It may just be the angle, but it appears to have no transmission... and the suggestion that it has no PTO may reinforce that thought...  if that's the case... it'd be a pretty lousy machine to operate...
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 9:45pm
Not true. If you are a tractor puller, I'm sure she'd roll the coal pretty well.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
feltennova View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote feltennova Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 6:45am
Not a fan (black???, just looks...weird), and it is hard to see in the pic, but looks like the builder did a pretty good job sticking it all together.  Guess the battery location was an after thought.  Like to see some more pics out of curiosity.
Bill Felten
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 7:58am
You know I've been thinking about it, a WC diesel probably with an automatic transmission. If it wasn't three states away I'd go look at it. And if it wasn't a cobbled up mess I'd probably buy it.
Yes it would get repainted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 8:41am
I like the concept. I believe a diesel WC would make an amazing puller. What one needs is a transmission out of a dump truck and probably a bigger rear end. Would not be stock but it would be cool to say your WC has over 200 horsepower(with a 12 valve Cummins). It seems a frame stretching may be in order. ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 6:29am
Well, if you're gonna put that much horsepower in there, you're gonna need taller tires to put the tractive effort to the dirt, and better change the wheels to something with more bolts....
So if you've changed the engine, transmisison, rearend, frame rails, and wheels/tires... there really ain't much left that's an Allis WC...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 7:32am
Back in my younger days as Pontiac fan, I wanted to shoehorn a Pontiac 455 V8 and auto trans into a WC and call it a WC 455. LOL
That Mercedes diesle wouldn't be powerhouse would it? I don't have a clue what the hp would be.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 8:04am
Back in the 70's we started with a junk WC and a 59 Plymouth. Stretched the frame, set the 318 with the pushbutton automatic in front of the tractor trainy. Dad made up a drive coupling and a lot of cuting and welding and it ran.
It was dangerous, fun and worthless. Hand brakes and rotton tires. But when your going down the road at 20 MPH and a car starts to go around you and you crack the throttle you get funny looks when the driver of the car can't get around you.
Hmm that sounded a little like something shameless would do.
Did i say it was fun?
The universal answer to all questions is yes, how much do you want to spend?
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 8:11am
Why???
Because he has creativity.
Rather than the ones on here that just keep rebuilding the same engine and painting them with the same orange paint.
After awhile that get's real old and it's time to do something different.
And you guys would really love to have that one!!!
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 8:57am
I think its cool!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 9:06am
I almost put an engine from a 220D Mercedes on a JD 45 combine but someone bought the motor from me before I could make the switch.
A 5 cylinder 300SD Mercedes Turbo Diesel engine is a sweet motor.
This page was generated in 0.625 seconds.
