fuel pressure question
giz's hd-6ep View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote giz's hd-6ep Quote  Post ReplyReply Direct Link To This Post Topic: fuel pressure question
    Posted: 21 Sep 2011 at 7:04pm
hello all, ran dozer for about 45 minutes other day and fuel pressure was on zero at idle when i rev engine it goes to almost 10 lbs .it runs good and smooth no misses but won't start without a shot of either even when it's warmed up .it hasn't been run in about 6 years ,wondering if it needs to be run a while to magically fix itself lol or is fuel pump shot .any adjustments i can do for more pressure ?? what should pressure be? also anyone have any issues with the low sulfur fuel does the additive work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 7:35pm
use a trial gauge to be sure the one on tractor is good. be sure filters are clean and no restriction on intake side of pump. Starting can be a pump problem or a compression problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote giz's hd-6ep Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 7:48pm
yea was thinking about using different gauge after i posted what should pressure be ?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 9:31pm
check it out, low fuel pressure will ruin your injection pump.  I have no idea on your machine but my HD16 is like 40-60 lbs fuel pressure per service manual.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 10:10pm
If engine has good compression, the pump is likely to be worn to where fuel shops describe them as not having enough start up pressure. The wear usually results from fuel not being kept clean enough. The American Bocsh PSB pumps are  very sensitive to dirty fuel just like injectors in two cycle Detroits - the very reason they both use the same fine filtration.  If your pump has to come off, find a fuel shop with experience in rebuilding the hydraulic heads on those pumps. They are not to be handled by any fuel shop that has no experience with them.    Mac
This page was generated in 0.527 seconds.
