D 14 oil pressure gauge
tominMi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tominMi Quote  Post ReplyReply Direct Link To This Post Topic: D 14 oil pressure gauge
    Posted: 19 Sep 2011 at 11:04am
My recently purchased D-14  has had the original AC oil pressure gauge replaced. The current one has readings up to 80 psi. With the engine at operating temp the gauge barely registers over 3 psi of pressure. Is there a difference between oil pressure gauges? What should the engine oil pressure be for a D-14?
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 11:18am
Try to find a gauge that just goes to 30 pounds max.
I use fuel pressure gauges 0-15 lbs on my B's and C's that never see 15 lbs oil pressure cold but they are small and for some hard to see.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 11:39am
Jeff is correct.  A gauge that goes to 80 will not read correctly in the 8-12 range.  We have factory style, or you can find generics that max out at 30.  That would still be higher, but finding one that tops out at 15 for oil is tough to find.
JimD
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 11:45am
The fuel perssure 0-15 work fine with oil but like I said they are samall. Mine is 1 1/4 inchs wide at the glass 1 3/4 wide with the chrome trim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 11:46am
Samall---Is that a word???
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 6:27pm
My '57 D-14 holds good oil pressure (more than 30 in the upper rpms). Is the tube in the oil filter in place?
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 6:47pm
Like several have said a 30 psi max gauge is all you need. You will see proabably see about 10 psi when it is running. The original gauge did not read a pressure. It just showed normal range. They have them on ebay. I posted a link below. Note that I have bought nothing from them. I simply found it quickly when I looked.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 7:42pm
 we have the original gauge  30# with name and word normal  [dash mt.]USA made
  1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 7:47pm
If the tube was missing, you would probably have 0 pressure showing.  Your gauge may not be correct if it shows 30 after it warms up good or your filter or tube could be restricted.
Edited by CTuckerNWIL - 19 Sep 2011 at 7:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tominMi Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 7:50pm
Thanks everyone for the replies. You have confirmed what I suspected regarding the existing gauge. Nick , the oil filter tube is in place. I'll be replacing the old one with a new one of correct pressure range.
Thanks again.
