D15 Series II Gas
coastga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coastga Quote  Post ReplyReply Direct Link To This Post Topic: D15 Series II Gas
    Posted: 16 Sep 2011 at 9:15am
My clutch went out all of a sudden on my 1965 D-15 Series II gas. One day I had plenty clutch and next day it bottomed out. When you press the clutch is whines like a throw out bearing on a car. Now it will grind going into all gears.
My question, where is the best place to get a replacement clutch as far as price and quality? Also, any suggestiions what may have caused it to go out so fast? I live in Georgia.
Thanks!
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 9:21am
When I did the clutch in my D19D, I got the parts from Sandy Lake....but I am sure Jimd or Tony from TonysTractors should be able to help you
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 10:39am
You will want Rick Corder to rebuild it. He is in the memberlist. If you buy an A&I or one from aftermarket it won't be right. I am not sure on the ones from AGCO, I bet they could be wrong too. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 11:27am
The one for my D19D from Sandy Lake fit like a glove, but I know what Tracy is talking about, had one from A&I in a D14 and one from auto parts in a D17, both failed and slipped within a year........springs in pressure plate not right. When we put it in, it wouldnt release.....adjusted figers on pressure plate and you shouldnt have to do that on a new clutch, they should be adjusted from factory
Edited by DonDittmar - 16 Sep 2011 at 11:34am
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote coastga Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 1:23pm
I talked with a local diesel (tractor) mechanic today, and he strongly recommends having the old clutch rebuild instead of buying one from the local AGCO dealer. He strongly recommends Savannah Clutch & Industrial Brake out of Savannah, Georgia.
I really believe my release bearing froze up instead of my clutch going out. But when I get into it next week, I will replace both the clutch and release bearing.
Thanks for the comments & suggestions!
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 2:42pm
I know this is a different tractor, so different clutch, but I got one for my D17 from Jim at OK Tractor, it was an A&I disc on the box, but opened it up to find the manufacture was rockford.  He was able to get it to me in two days ground delivery.
Still in use:
buttonman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote buttonman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 5:08pm
i have done a couple clutch jobs on my d-15 diesel and what happens is the center of the clutch plate breaks out. check the bottom of the bell housing for the inspection plate which is around 2.5 inches across. the bits of springs will be lying inside on the bottom. this means splitting the two halves and walking them apart which is not that hard if you are on concrete and use some 12 inch ready rod or bolts with the ends cut off to guide the halves back together.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 6:41pm
buttoman could be right, I have don two D14's and thats what I found, the centers were loose from plate. Let us know what you find!
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 7:41pm
That is what I did on my 15 II.  There is a place in town called clutch and brake.  I guess I got the same one back it sure looked spiffy.  The tke care of new clutch disks also.  Works like a champ and was less than ordering a kit on line.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 8:32pm
I would split the tractor and send the worn parts to Rick Corder. He will do a fine job restoring your parts and you know what you have will work properly.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 8:54pm
I have a D/14  my dad bought new . He had to replace clutch dise twice. The centers broke out. He thought it was caused  from quick shifting of the power director back and forth espesily pulling combine with pto. Weigh off machine could put more pressure on clutch than HP of engine would be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coastga Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 3:36pm
Foiund out today that my release bearing exploded. destroyed the Release bearing carrier. Will a AGCO dealer carry this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote coastga Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 3:59pm
The technical name for the release bearing carrier is "Clutch shifter". AGCO part number 70245259.
The problem is that AGCO does not have it!
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 4:07pm
Sorry, I should have given you that number when I looked it up a little while ago!
Let me know if you still need one.
JimD
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 4:14pm
I may have one as well if you run into a snag......I have a D14 I parted out....not sure what is left in the torque tube, would have to check
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote coastga Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 6:44am
Jim,
I hope the rain stopped long enough for you to pull the part and send it on its way. If your State is like Georgia, we are in dire need of some rain. Our local rivers are at a 100 year lows. I feel for Texas!
Steve
