WD throttle help
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: WD throttle help
    Posted: 15 Sep 2011 at 10:47am
When I set the throttle lever on my WD to low idle and if you hit the steering wheel, or anything in that area lightly, it slides to half throttle. It has been getting worse the past few times I have used it.Now, if you set it to low idle as soon as you let go of the lever it will go to half throttle. Now I need to wire it just to keep it at low idle. What could be causing this?    Thanks
Edited by Josh Day - 15 Sep 2011 at 10:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2011 at 8:28pm
bump
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2011 at 8:33pm
   The friction blocks may be worn out or the spring behind the quadrant may be broke. Or both of these.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2011 at 8:42pm
Is the spring under fuel tank hooked up?
  RFDEERE is most likely correct.   MACK
This page was generated in 0.057 seconds.
