XT transmission
Cody nwo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cody nwo Quote  Post ReplyReply Direct Link To This Post Topic: XT transmission
    Posted: 12 Sep 2011 at 10:31pm
Found out today that the driven gear on the counter shaft in my xt's transmission has most of a tooth missing. Anybody know how hard it is to replace? any short cuts are much appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 7:18am
Complete and total teardown of the rear end and transmission......lot's of hrs and tooling to split and remove rear wheels and axles, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 7:21am
That shaft is the last thing to come out of trans.  MACK
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 7:55am
Sounds like putting a gear in the transmission of a D series. Changing the gear aint bad.......getting to it is the problem
1968 D15D,1962 D19D
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 8:22am
I don't have one, but it sounds like fun:)
Edited by Josh Day - 13 Sep 2011 at 7:16pm
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 9:22am
Just be careful when you do the rear split.  On my 7000, the rear end wanted to tip backwards, not forwards.  I had a feeling it might do that, so I was able to catch it before anything happened, but it is something that could be potentially disastrous if overlooked.  Seeing the 190xt has a similar rear end to the 7000, I would imagine it would have a similar weight distribution.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 10:49am
This is a picture of the correct stand you need to do the job. I don't remember who this is but he's a forum member. This is exlactly like the stand we used at the AC dealership I worked at.
Wink
I am a Russian Bot
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 8:43am
The fella scratching his head tells the story there Lonn!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cody nwo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 8:01pm
Is there not enough room under the pinion to press the shaft back and pull the input shaft out of the trans to get the gear out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 8:14pm
Nope........there's 10 gallons of gears stuffed in a 5 gallon compartment.
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 9:14pm
The guy in the picture is me.  My One-Ninety was a nightmare to go through, but runs and drives like a dream now.
Matt Folkers
FOLKERS RESTORATION
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 10:02pm
Cody I have a 190 rearend.....this tractor came off an Amish farm....was used for stationary pto work if you would be interested in swapping out rearends.  I have bid a number of these jobs and NOBODY understands or can comprehend the amount of work involved.  Unfortunately they scrap them instead of repairing a good machine....anyway lots of work ahead of you....good thing is there are alot of helpful people here and mucho knowledge-o         :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cody nwo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 9:08pm
I'm not sure if I'm gona repair it or put it back together and see how long it'll last now. It won't be used for much heavy pulling so hopefully it'll last until I have more time and money to do it. Is it a series III rearend though?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 9:23pm
If it is the front gear on bottom shaft, it won't last long because it drives all the gears except 4th.   MACK
