Will my 220 pull a 9 shank disc chisel?
Luke R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Topic: Will my 220 pull a 9 shank disc chisel?
    Posted: 12 Sep 2011 at 9:48pm
I bought a 9 shank AC min till model 1500 disc chisel the other day. Is it too big for my two twenty? It is turned up some but not over 175 hp. I guess i will let you know for sure this fall. This looks to be an awesome chisel with super high clearance and very well built.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2011 at 10:16pm
Only problem I see may be traction.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2011 at 10:57pm
I pull 11 shanks, 3.5" twisted shovels with my 7040, 7060 and 7080 with no problem. I have loaded tires on the 7040 and 7060 and 4 wheel weights on the 7060 and 7080. 140hp on the 7040 and 210hp on the 7060 and 7080. Full stack of weights on the front. Ed is correct traction will be your only problem in some conditions as I have that problem too pulling 10 to 12" deep
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2011 at 11:02pm
My 7040 ..used to play with one ..........
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2011 at 11:56pm
Here a 7 shank is all a 8030 fwa wants.
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 4:48am
We pull a 9 shank with our 220 loaded centers with duals. We had ours put back to a little over stock horse power. If the ground is real hard we have to put it in third. Our 210 does a good job also.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 8:45am
Shows the differances in soils. With the old tired engine we pulled 10 twisted shanks in 4th and we have the fast low range in our tractor. With the new motor we pulled same in 5th and look back now and then just to make sure the hitch pin didnt fall out, LOL. tractor is on 18.4-38s dualled up and fluid on the insides and  a rack up front. If it doesnt rain until the fourth of July this coming spring I hope to have some seat cam vids to show off.
oops should have read better, this is just a plain chisel not a disk/chisel.
Edited by Butch(OH) - 13 Sep 2011 at 10:31am
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 10:26am
Would you believe this picture?
In all seriousness I pulled a 5-shank gencoe with a 6080 fwa and like Jordan now pull this AC 7-shank with a 8030fwa and hover between 5th and 6th (power shift) gear depending on if I am driving up a grade or down.  Our soil is on the heavy side and some of my fields have a roughly 20' elevation change on a 6 acre field.  I agree that when you put the AC next to the glencoe it is built so much heavier and with greater trash clearance.  It sure is a nice machine.
Mike
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 10:50am
Bought an 11 shank Landol disc chisel a few years back just for the 210 I was the 3rd owner. The first guy pulled it with a 4840 than a 4850 FWA, the second guy pulled it with an older Versatile at around 180hp 4WD my 210 has 18.4-42 radial DA duals insides loaded, 2500# on the front and 210hp under the hood and it pulled the landol into pieces, ripped the steel that the hitch was hooked to repaired that and beefed it up and it ripped the front off, so we cut it up and kept the pieces for another machine we are building.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 10:52am
Mike
That's a cool pic Michael. Reminded me of back when I was farming. Our place was on a busy state road and one year when we happened to be ahead of the game so each day for a solid week after work in the evenings I worked corn ground out by the road with the 190XT and 16' HD IHC disk  And just to fool with the neigborhood nib-chitters I would unhook the disk in the field, but out by the road and after dark. Then drive the XT to the house. We had about 10 sets of rear Farmall weights so I put them all on Dad's Farmall H. Drove it to the disk each evening hooked the disk pulled it far enough (first gearLOL) to cover the tracks and left it parked out where everyone driving by all day could see it, had a lot of fun with that. Wish I had dreamed it up on my own. Idea came from a neighbor who regularly would pull 2 empty 350 Kilbros gravity beds w/tiptops to the field with his 10HP Cub Cadet, Fill them to the top with corn and leave it there long enough for 100s to drive by and see  the rig and pitch a bi,,, about dumb S..,,, trying to pull 2 big wagons with his garden tractor. Guess we had too much fun farming and screwing with nosy people, LOL
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 11:30am
LukeR, anticipation is a meany, isn't it? At 175 hp the easy answer is YEP! If it wont something is not kosher. I pulled a 13 shank IHC with 4" twisted at about 6.5mph with my 7060, 20.8X38 dualled, all four full of fluid, at 225 maybe 250hp. The only thing that old girl backed away from was traction as the others said. You will need plenty of weight on the rear,but other than that you're good to go!! You will be impressed fer sure!! Happy Days!
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 11:41am
I pull a 9 shank glenco with my 7080. Full front weight and 2 of the big rear weights on each side as well as cast center duals. Traction is its only problem and its at stock horsepower. Of course my mom used to use a 7580 to pull a 9 shank sunflower disc chisel and it would be all it wanted at times.
Making a living farming with and working on Allis Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 2:35pm
Butch,  I can not imagine you stirring the pot like that.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 9:33pm
You should be fine.  8030 had no problems with 7 shank disc chisel.  11 shank chisl plow is just about right behind the 8030 the 7080 has great plenty of power to handle the 11 shank.  I know I'm not exactly comparing apples to apples.  In small places and pinch situations  I have used the 6080 on the 7 shank for very limited use it is fine. If the ground is as dry as we have only got 2.5 inches in the last 3 months then the clay represents a traction problem.
