190 throwout bearing
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: 190 throwout bearing
    Posted: 09 Sep 2011 at 8:45pm
Is there any servicing that can be done without splitting the tractor? I put a new clutch in 300hrs ago and now I have a dry bearing sound when I push in the clutch pedal. Any ideas what to do, or do I have no option but to split it and replace it?
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2011 at 9:42pm
Was the bearing replaced when clutch was replaced?  If it is thrust bearing, nothing to do except split it again.   MACK
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2011 at 10:53pm
Had the same thing happen with our 200 loader tractor. Go get the longest 1/8 drill bit you can find and drill a hole in the outside of the brg., then you can lube it with a neddle, rotate it several times and continue to add grease, put a dab of rtv over the hole when finished. It will live until the clutch needs relacing again, then you can drill the hole bigger and install a small grease zerk. Good Luck, Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2011 at 11:40pm
Thanks Mike that is a great idea!
Allis Express
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2011 at 7:36am
I'm having a hard time believing a new AGCO throwout brg has failed in only 300 hrs of use. Whenever replacing a clutch, you better be adjusting the freeplay of the clutch pedal to be 4 inches minimum (180-190-200) and maintain that distance. Too little freeplay and the throwout brg MAY be spinning all the time which will surely cause a premature failure. Again, I've never seen a failure of a NEW throwout brg  if adjusted/maintained properly ( and the operator leaves his foot off the clutch pedal) in only 300 hrs use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2011 at 9:52am
Mine didn't fail, it just got dry and noisy, after lots of loader work and yes I kept the clutch adj. I could never figure out why A-C put a greasable brg. on the wd/wd45's and not the bigger models. Lots of good info in your post Doc., Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2011 at 10:13am
They quit making it a greasable brg because people overgreased it and grease would get on the clutch. The standard pre-packed throwout brg will generally out-last the clutch (as a rule) if it is kept adjusted properly AND the operator keeps his foot off of it.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2011 at 2:30pm
Could it also be the pilot bearing?  If it is getting hard to shift, I would suspect a pilot bearing, but I had a throwout bearing go bad in a year, but it was an A&I aftermarket bearing.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2011 at 10:02pm
It shifts fine, I can't remember where the clutch kit came from, its likely not from agco. This is also a loader tractor, but I don't abuse the clutch, adjustment is fine.
Allis Express
This page was generated in 0.441 seconds.
