200 Drawbar Bolts
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Topic: 200 Drawbar Bolts
    Posted: 08 Sep 2011 at 9:40am
My 1974 Model 200 tractor has 2 square headed bolts to keep drawbar from sliding side to side. These bolts come up from bottom and are held in by lynch pins. These 2 bolt are available from AGCO for $38.76 each. Is there any other source for these bolts that might be cheaper? AGCO part#---70269953     Thanks for any help !!!!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 10:12am
Make em
Wink
I am a Russian Bot
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 10:43am
Usually because nobody lets the drawbars swing anymore they are replaced with regular bolts and the roller just bumps up to to them, if you want to make it so it can swing use a pin, and if you wanna makem really nice and tight, our steiger has a nice idea they have an angle iron that presses against the roller and a pin welded that drops in the hole it keeps the drawbar tight and can be pulled to swing it for hook up etc. Heres a trivia question does anyone know why the drawbars should be allowed to swing when doing tillage type work??
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 10:49am
It makes it easier to steer the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 10:56am
yeah your correct it pulls the front of the tractor around on a turn, I never knew that till my  grandpa explained and demoed it makes sence
