8010 steering/smoking
jjpetrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Topic: 8010 steering/smoking
    Posted: 06 Sep 2011 at 9:10pm
The steering on our 8010 pulls harder when turning left but almost steers itself right and was wondering if there is a skrew or something that could ajust it?   It doesnt smoke when under load but when it does it smokes and it doesnt use any oil.
Edited by jjpetrich - 06 Sep 2011 at 9:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 9:50pm
Steering sounds like centering springs are broke or crud in steering valve.
   The smoke problem, would need more info.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 10:41pm
Thanks for the help.   It idols perfect and everything its a little hard to start but starts good and if its running a pto or pulling something it smokes the entire time, not a deep black smoke but you can tell its there.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 10:48pm
All mine smoke like that. Only the 7040 uses any oil and its a very small amount, maybe a qt per oil change. They range from 150hours on engine (7080) to 1200 hours on engine (7060) to 9300 hours on engine (7040). The 200 will smoke a little bit too, but it doesnt get the work the others do. Id say its just nature of the beast.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 10:52pm
Thanks for all the help!
This page was generated in 0.093 seconds.
