WD/WD45 starters question
LarryWC In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Topic: WD/WD45 starters question
    Posted: 06 Sep 2011 at 6:45pm
Hopefully, this will be an easy question here.
What is the current draw on a healthy WD/ WD45 starter under load?
www.allischalmersmuseum.com
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 9:21pm
Larry !!  from  my I n T manual.   No load  5  volts , no load  60  amps, no  load  rpm  6000, lock test  3  volts, lock test  600 amps , lock test  torque, ft  lbs   15.
Hope  that  helps.        Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 9:11am
Thanks Tony!
