WD hydraulics misbehaving
Embellem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Embellem Quote  Post ReplyReply Direct Link To This Post Topic: WD hydraulics misbehaving
    Posted: 06 Sep 2011 at 1:07pm
MY WD has a 3-point conversion on it and it's doing some strange things.
First, sometimes when I lower the control lever on the quadrant all the way to the bottom, the lift arms won't go down. They will eventually drop, though it could be a few seconds up to a couple of minutes.
The other thing it will do is sometimes when the lift arms do go down after lowering the control on the quadrant, the arms and control lever will go back up automatically like there is back pressure someplace.
Any ideas? Seems like it has a mind of its own sometimes.
Terry GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry GA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 1:29pm
Could be to much play in the linkage rods or just out of adjustment.May just need to adjust a little and try it.Kind of like "Fire and and adjust caliber 50".....walk it in.
I couldn't repair your brakes, so I made your horn louder.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 8:01am
Check to make sure that your hydraulic oil level hasn't gone down-  if the oil's getting aereated, it'll cause the valve to act funky, and the arms to magically lift themselves for no reason...
Oh, and check the level COLD... like... after it's been sitting for a day or so...  when it's aereated, the level will ALWAYS appear to be high.
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 8:33am
Check the Traction Booster linkage bolt which should be screwed in along the bottom, left hand side of the pump. It this isn't secure the lever won't stay down.
This page was generated in 0.352 seconds.
