Odd tractor rear drive system
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: Odd tractor rear drive system
    Posted: 05 Sep 2011 at 1:22pm
OK what is it ? says English  Ford Major gas engine and year of 1953 and test but nothing on the rear drive just gives front tire and
Edited by Coke-in-MN - 05 Sep 2011 at 1:30pm
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 1:24pm
Looks like it might be a ruff ride!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 1:31pm
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 1:44pm
Howard rotoped drive system.Useing chains to pick up pads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 1:48pm
Looks like a walking design. May not be as rough a ride as it looks.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 4:57pm
Not rough-riding, it's just a variation on the tracklaying concept, just uses longer 'shoes' than what you'd expect on a track-type.  The US-standard 'method' is to have several bogey wheels and short-plate 'tracks'... doing a track conversion with short tracks involved adding at least ONE additional wheel up front, and a series of wheels to distribute weight across the tracks.
This configuration didn't require all that- it basically just bolted on in place of the stock wheel.  If you look closely, you'll see that the wheel is directly supporting the whole rearend weight of the tractor, and instead of having a 'tyre', it has cog-teeth that roll along the track plates.  If you're working soft surfaces, you get the added surface-contact/lower surface pressure advantage, but I kinda doubt this conversion would've been 'happy' maneuvering around tight quarters, especially after the pins got worn.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 7:56pm
I would think that the smaller roller chain would be prone to breaking and coming off ALL the time, since it runs in the mudd and rock???
Still in use:
jnicol6600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnicol6600 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 8:17pm
I've seen them on youtube pulling trenchers very slowly
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 8:22pm
I don't think the roller chain is supposed to be in the mud. The shoes are on the ground, that chain shouldn't touch the ground unless you bury the tractor in the mud and you would be in too deep to keep going.
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 8:26pm
I owned a Super Major back in the day and it was  a diesel. Started alttle hard,but pulled good. Needed power steering ,unless you had something heavy on the 3pt.  Always been somebody tryng to perfect the "half track" system for wheel tractors.
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 8:40pm
not too bad really, here's one going along
http://www.youtube.com/watch?v=f6RtTo3aNr8
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 9:47pm
A very good point, but if you look carefully in the first picture, the sprocket is exposed through the knuckle or joint of the track, and that may expose it to debris.  Even the one on the floor still shows the chain through the joint.  I don't know for sure, just a thought
Still in use:
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 9:51pm
Yes, watching the video, it does ride quite smoothly, wouldn't want to go too fast though!
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 5:12am
Hee hee... the small chain isn't really SUPPOSED to be in the mud, but regardless, it's gonna get dusty and dirty... the dusty-dirty 'level' for any tractor, is about three feet above the operator's head. The front edge 'rollers' and pins on those plates definately take a beating from dust and grit- no escaping that fact.
But the little chain doesn't 'drive' anything... the driving is done by the big cog teeth on the replacement 'wheel'.  The little chain's job is to make the track segments pick up, and 'lay out' in a smooth fashion, so it's really not under a load.  The big wheel rolls across the plate segments, they're picked up by the opposite plate, and pushed forward by the 'top' side of the big cog wheel, then laid down, and driven over again.
My gut feeling here is that, even if that small  chain was broken, it would still drive, but the plates would probably bang around pretty good... mebbie get bound up every so often, but not much more.  It's a clever design, but there's probably a reason why it didn't take the world over and replace tires or short-plate crawler tracks.
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 8:44am
Fantastic! thanks coke for both the op AND the u-tube link!
