Allis D grader
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Topic: Allis D grader
    Posted: 04 Sep 2011 at 9:39pm
This may not be the right spot for this, but.  I looked at a '53 Allis 'D' grader today with cab. It is complete and in good working condition. Might need a little front end work like tie rod ends.
Anybody have any idea as to the value of one of these??  He's asking $10,000 OBO. I thought it was a little high.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 6:12am
Phil, it depends on a lot of different things. I'd say $5000 is closer to the mark but a restored early 'D' grader with the WD engine and no options sold at a collector sale a year ago for $8200. I looked at a 67 'D Special' with all the options, square frame, D-17 gas engine, power steering, tilt front wheels, power circle, hydraulic blade slide, deep reduction transmission, but had a broken drive axle on one side $8500. I'm using a friend's 'D special' for some yard grading this week. Great little machine!
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 8:47am
Some people still think it 1995 when it comes to tractor pricing.
D-allis Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 10:14am
I just bought model D Square farme with with cab and all options new correct tires and extra set of new tires and chains completely restored for 8000. It was in old allis news a few years ago. Just done it this morning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 10:52am
You did good at $8000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 9:51am
This one is unrestored, original condition. Rear rubber looks OK, but fronts are pretty tough. They are holding air, but barely!  Scraper edge on the blade is worn and bolt holes are worn from running loose.  I'm thinking about $5000 max.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 5:50pm
i was thinking $6000.... but a lot depends on location, how far do you have to haul, and how bad do you want it ?
