615 diesel backhoe
tonysac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tonysac Quote  Post ReplyReply Direct Link To This Post Topic: 615 diesel backhoe
    Posted: 04 Sep 2011 at 8:59am
hello i am trying to put the 615 backhoe together i saved from scrap and can't figure out how or where they mounted the air cleaner or if i even have the correct one. Pics or parts breakdown would be appreciated,it has the 2200d engine, thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote tonysac Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 9:14am
sorry had a brain lapse,i believe it goes in front of radiator,thank you
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 6:17pm
That is correct. According to the owners manual its located is in front of the radiator. Do you have an air cleaner assembly. If not I may have a new one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tonysac Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 9:03am
i do have a air cleaner off a I600 but somebody put in a bigger radiator and i assume the intake pipe goes over the radiator ,so there is no room for the pipe, i will have to mount it on the loader frame thank you
This page was generated in 0.277 seconds.
