Weights for '48 B
Allis B in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis B in PA Quote  Post ReplyReply Direct Link To This Post Topic: Weights for '48 B
    Posted: 03 Sep 2011 at 5:16pm
Hey everybody,
Brand new to tractors so I don't have a whole lot of knowledge.  Recently inherited a '48 B that was my grandfathers.  With a lot of help from my father in law we got it running again.  I have 2 way plows, cultivators, and a belly mower.  I would like to get some weights for it as well for the front and back.
I noticed mine has a bar in the front that I haven't seen on other B's...Is this something for putting weight on?
Any help would be appreciated, I'll see if I can get pictures up.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 6:02pm
I'm guessing your bar is for pushing stuff around but it could be used for some weight maybe, not sure how secure it is on the front axle. For B's there are side weights that go on the motor and rear wheel weights and also front axle weights for wishbone front ends, not sure about ajustable.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 7:09pm
AHA!!!!
Welcome to the group, Doug!  If you don't find the answers here, the question is obviously metaphysical, 'cause all the other questions can be answered either by photos, or other AC enthusiasts.
Now, I say AHA... because I have a '48 B ALSO... and although mine does NOT have the adjustable frontend, it has wheel centers like yours.  I was told that mine SHOULD have had flat-type (non-dished) centers like what appears on my '39 B... and should've had some other type of wheel, but I see that yours (having 5-lug center sections) that my '48 is most likely correct, at least everything except the rim is.
My guess, is that someone either made a 'special' implement to mount on that, or they used it for either a weight bracket or bumper, or both.  It's cleverly done, with exception that it's position precludes easy use of the hand-crank if you should need to start it by hand.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 7:49pm
with a wide front like that I think it would be easy enough to fabricate a bracket for the smaller suitcase style weights.
The side weights can be pretty expensive.
Charlie
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 9:09pm
I have a 47 B with the same axle configuration as yours. The rear weights are the same as for the C, and get mounted on the inside of the wheel. For the front you would need the "side weights" They mount between the toruge tube (5/8" bolts) and the front mount on the front of the engine (also a 5/8" bolt). I guess that you don't have fluid in the tires. If you did, that would be enough weight to plow with.
Wher do you live in PA? I'm in Hellertown, near Allentown. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis B in PA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 6:20am
Thanks for all the info.  I do not have fluid in the tires, I'd rather not mess with that.  I've seen the side weights, but I know they are kinda rare.  I noticed that the front bar had the same paint as the rest of the tractor, just curious if it was an option for the B's.
Bob, I live in Williamsport, the tractor currently live at my inlaws, not sure my landlords would like me taking up parking spots with my B at the townhouse complex
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 8:30am
your bolted rear wheels were optional equuipment that came  with the adjustable front end.. standard was spline rear and widhbone front axle.... the weight bar is home made.
Edited by steve(ill) - 04 Sep 2011 at 8:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis B in PA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 6:37am
Any one in PA have wheel weights or engine weights they are looking to part with?
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 9:53pm
Do you know Fred yet????  LOL
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis B in PA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 6:58am
Nope, I do not have the pleasure yet...
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 1:25pm
Pleasure!?!?!?!?!?! HAHAHAHA
Where at in PA are you? I'm in Lancaster (home) and Doylestown (College)
You'll find quite a few of us B guys lurking here in PA. Let us know if you ever need anything. I'll keep my eye out for another set of weights...theres a farm sale up outside of Myerstown that has a few allis's, might want to skim over the sale bill. Search Horning Farm Agency. It's the sale on the 24th of september.
thomas davison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thomas davison Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 2:49pm
Allis B in Pa,  I live in Canton, Pa, 40 miles north of you.  Sorry, I do not have any of the weights that you are looking for.  Welcome to Allis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis B in PA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 5:35am
I found a set of weights for a B for sale not far from me.  There is no pictures or any info until I call the guy.  Will any wheel weights made for a B fit the 5 lug rear wheels?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 5:48am
Have the rear inside  weights like you need for that  rear hub on your tractor. Call me at 717-451-6590 after 6 pm .I am in Hanover Pa . 15 miles east of Gettysburg .
$60.00 for the pair.
Edited by Fred in Pa - 27 Sep 2011 at 6:43am
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 7:38am
Adding a water/antifreeze mix to the rear tires for weight is simple enough if you have accesss to a tank sprayer. Calculate the number of gallons required for your tire size from a Ag tire ballast chart and mix the required amount in the sprayer tank. Remove the spray wand from the 3/8 hose and slip it the hose over the valve stem on a flat tire and go to pumping. Position the tire where the valve stem is at the top and fill to that level leaving a air space. As you pump in fluid the tire inflates. Let out some air and replace it with fluid until you reach the full level. Air up the air space to about 10 psi and your ready go to work.
    Calcium Chloride and water is heavier than water/antifreze  but very corrosive to rims should you spring a leak.
    AC manuals did recommend CC and Water for tire ballast but I don't like it.
    With the weights from Fred and ballast you should have more than enough rear weight to plow pretty deep.
     With both plows mounted and up up you will need some extra weights up front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis B in PA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 7:54am
Thanks for the info.  I certainly need weight for the front.  Tried plowing the other day and steering was all but gone with the plows on.  I have some access to some lead, thinking about making some homemade weight for the front...any ideas?
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 9:37am
Mr. B in PA, a 4 or 6 inch piece of PVC drain pipe filled with concrete makes a dandy weight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 1:50pm
if you have access to lead it makes a dandy weight. The previous owner poured the front rims flush with it. Each wheel weights about 150lbs. If you do this you can't remove the hub from the rim. I have separate rims and hubs if I don't need the weight.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis B in PA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2011 at 12:21pm
Fred,
Definetly interested in the weights, Work has been crazy and have been working late all week.  I will try to call you next week about the weights and try and set something up.
Adam
This page was generated in 0.574 seconds.
