WD45 Diesel Puller
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Diesel Puller
    Posted: 03 Sep 2011 at 2:55pm
One of my relatives many tractors. Pretty sure it has a 301 in it but he won't take the side covers off....
Charlie
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 9:57pm
weight class
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 10:10pm
Definitely not a 230/262 oil pan showing underneath...
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 10:23pm
looks like an electric cooling fan infront of the rad
if farming was easy everybody would be doing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 7:23am
4500 lb class I think is the lightest he can do. 5000 is what is set up for at the moment
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 11:07am
Drawbar would never pass a good safety inspection......no side to side support.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 11:17am
Exhaust is on the wrong side for a 301, unless it's got a multiple charger set up...
Hurst
1979 Allis Chalmers 7000
5800 Hours
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 1:09pm
Looks good other than the draw bar.  Like the Dr said, needs some side support
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 1:15pm
i would think its got to small a tire for a 301 with chargers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 6:50pm
Hurst
It could have a crossover pipe. The original Buda 230 the exhaust is on the rh side of the engine. They have a pipe that crosses over to have the exhaust on the left like the gasser.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 8:53pm
the exhaust stack looks centered to me.
