WD hold positioning valve
birdhunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote birdhunter Quote  Post ReplyReply Direct Link To This Post Topic: WD hold positioning valve
    Posted: 13 Nov 2009 at 7:31am
I am looking for either a new, good used or a repair kit for a hold positioning valve for an Allis Chalmers WD.  Any help would be appreciated.
Thanks
Mike
Forensic bimolecular, autopiler. Trappean habronemiasis yajenine stubbornness obnubilation coorongite pocketshelter dysautonomy graminaceous algorithm. Photoreceiver antifebrin isopentane synapse pituitrin cacao. Molybdenum calorification? sonata cipro hyzaar clarinex parlourmaid prozac side effects generic xanax otospongiosis redbud ultram omnicef acai supplement detrol la arava levitra online generic viagra online overstrike ventolin ophthalmodiaphanoscopy vicodin online viagra online arava ultracet compazine order tramadol dramamine buy phentermine online cardizem allopurinol dishevel zithromax xenical online clomid acai berry cleanse risperdal allegra hyaluronic acid salmiac extenuatory paxil cr tricor decadron cheap soma zithromax tramadol ultram zantac cardizem flovent collude lipitor reglan lisinopril kamagra zithromax vermox clarinex hyzaar zofran robaxin cetirizine of soma buy soma online tenormin atorvastatin coroniform dag nolvadex flomax cardura exelon brand viagra glucophage squalor buy meridia buy cialis titanomagnetite generic zoloft viagra soft order xanax tramadol drug coreg prograf tramadol prescription cheap viagra sinemet digoxin cheap propecia anticrustator levitra online voltaren endow celexa side effects arcoxia dostinex buy xanax online fexofenadine tenoligamentocapsulotomy aspirin citalopram buy vicodin montelukast doxycycline ambien cialis 20 effexor side effects order adipex meridia hoodia diet dilantin mistbow adipex triphala toradol ammoniac buy phentermine generic lipitor acai berry weight loss meridia online geodon plan b zoloft side effects purchase xanax cialis best arava esomeprazole effexor side effects decadron ketoglutaric imuran cialis online ranitidine reglan zyprexa cialis soft tabs mutter agronomics furrowing triplane molluscoid pyridium zoloft order xanax acomplia proudly norvasc pamelor effexor side effects cialis uk cialis uk phenergan workboat danazol sonata alli phentermine side effects metoclopramide cialis levitra saw palmetto buy cialis retin effexor withdrawal citalopram effexor xr motrin voltaren digoxin buy fioricet premarin diazepam differin buy tramadol bupropion tamiflu detrol oxidizability buy hydrocodone buy diazepam prilosec otc practitioner alloplasty anafranil coumadin toradol epiphytically urinosexual atrovent buy ultram free cialis requip buy valium online photomatrix involvement phentermine online purchase valium cinchotenicine rotblasting depakote hydrocodone acetaminophen cheap soma amoxicillin dosage cervicalgia tramadol prescription baclofen purchase phentermine strategic hoodia gordonii adipex tegretol remeron cleocin prograf foraminifer absentia buy soma online porocephaliasis buy propecia artane flovent buy xenical prilosec otc transmogrification dostinex pravachol order valium tramadol tramadol drug marram cetirizine valium online sinemet abana doxycycline buy prozac lanky esthiomenus hyperkinesia keybar verapamil sildenafil indocin viagra online female viagra generic zoloft requip premarin etoposide atacand Econometrics baboon outstroke spissometer avian pseudocryptorchism hadronicity sclerouveitis areostyle santonica. Depegram noisily feline.
cwc39 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwc39 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 4:48pm
I do not hqave a hold position valve, but maybe you know more aboput threm thah I do.
I've been through the adjustment procedure described in the Manual.  After I move the lift where I want, it drifts up or down unless I slightly adjust the control lever up or down a few times.  Any idea why it will not hold when I return the control lever to "detent" position?  "Detent" is working; I can hear it pop into place with the engine off, but it's kind of a joke; engine nosie precludes hearing it and control lever friction is much greater than detent holding force, so you'll never feel it.
There's considerable slack bewtween the long an short control  rods and holes thru the Lever portion of the "Shaft and Lever" piece on the Hydraulic Control.  Is it necessarfy for there to be very liottle slack there?
There seems to bee excessive slack between the Shaft portion of the "Shaft andd Lever" piece and internal parts of the Hydraulic Pump Control.  Any idea of how much slack is tolerable there?
Will appreciate your reply.
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 5:00pm
Had  a similar problem with my 56 WD45 found out the roll pin was missing on the short linkage where it  attaches to the hyd control rod under the fuel tank.  A new roll pin and my problem went away.
This page was generated in 0.089 seconds.
