Snap coupler blade ?'s
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Topic: Snap coupler blade ?'s
    Posted: 30 Aug 2011 at 11:43pm
Hello. I have found a snap coupler blade that a guy has for sale and am thinking of picking it up. I was wondering if it could be disassembled easily to fit in the back of shortbed  pickup?? What would it entail? What size wrenches, sockets etc needed? What's it weigh?
Thanks!
Ben
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 12:00am
   Shouldn't have to disassemble anything, unless it has extensions.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 7:33am
Put the drawbar up vertical and load it. Once in place you could swing the drawbar down, but if it won't fit lengthwise, you don't have to close the tailgate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 7:34am
weight?? HEAVY for it's size.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 7:41am
You don't say what your pick up is. If it is something like a Ford 150 with the short bed -- should fit without taking apart. Loading and unloading is the hard part. When I got mine the seller had it already in the bed of a pickup and we just slid it from his to mine. Back at the farm I unloaded with chains and a loader tractor. Seller said that he and his son loaded it --- strong fellows.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 7:41am
I bought one several years ago. When the promised FEL tractor at the seller's place was unavailable due to snow, my helper and I separated the blade from the frame to load it as it weighs several hundred pounds assembled. Took just a few minutes, though I don't recall what wrench sizes we used.
WC, CA, D14, WD45
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 8:57am
We are assuming it is an Allis blade.  Some after market SC blades are out there.  The main beam attaches to the blade frame with one really BA snap ring.  If that ring comes off, the two parts separate quickly.  (Boy, don't ask me how I know that!)  As an aside, if anyone knows where to get a new snap ring, please let us know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 10:18am
Sounds like Dave Richards and I have had a similar experience! It was pretty exciting when that ring broke.  I fabricated a replacement "ring" - so far, so good.
WC, CA, D14, WD45
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 10:34am
I lifted mine in a tree, backed the truck/trailer under and loweered the blade into the trailer....at the other end revearse...
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 1:08pm
Someone was wondering what I had for a pickup. I have a F150 supercrew with the 6 ft box, but..... I have a toolbox in the front that takes up about 20 inches....
Ben
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 3:54pm
Would easily fit without toolbox. With the box, most likely you would have to take apart into two pieces or load with the tailgate down and strap her in good. If you can load and unload in one piece - I'd strap it and go.   Comes apart as other have said with a snp ring if it is really Allis. Not real hard to get apart but do risk breaking the ring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 4:38pm
I hauled my A/C 3 pt. blade w. one extension home from the auction in the back of my full size PU ww. a topper.Auction had a boom tractor,chained it tight and he set it in back slicker than snot.Slid it out part ways and winched it down from a tree branch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 5:16pm
Rent a small trailer to pull behind your pickup; load the blade with the SC tongue towards the back of the trailer and tie it down, get home and slide it where it needs to be to reach the tractor, hoook up to tractor and drive away. SC blades are pretty easy to slide around on a trailer as they are not that heavy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 6:14pm
Thanks for all your replies everyone! Its an Allis CHalmers blade. I guess I'll see what it is when I go look at it. What's the going price for these??
Ben
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 7:21pm
     We get between $250 and $350 around here, Madison county Illinois.
This page was generated in 0.469 seconds.
