wd and 4 bottom plow
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Topic: wd and 4 bottom plow
    Posted: 30 Aug 2011 at 11:28pm
Will a WD pull a 4 bottom plow? One coming up at auction near me, they tend to sell for next to nothing and I'm interested as I have some breaking to do. Cant tell brand as it is locked up until sale day. It is a trailer type if that makes any difference, thanks, Trev.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 11:45pm
Should, with proper weight distribution and low gear a wd will pull quite a bit. if a 45 gasser can pull a 4 like a d17, the wd should handle it OK, but it depends on what you are pulling in.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 11:57pm
    A WD WILL NOT pull a 4 Bottom, unless it is not in the ground !
http://www.rumelyallis.com
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 12:55am
My WD has a pretty good load with a pull type 2- 14's in our good soil, the clay really works it. It does better with the 2 bottom mounted (pin hitch) I don't think a WD would handle a 4 bottom unless you've got sand and / or the motor had been souped up.
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 1:38am
My thought is that it will be too much for the wd.  The WD is way too light to pull a 4 bottom pull plow not too mention under powered.  but hey if you can buy it cheap go for it and see what happens
1955 WD-45 with factory PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 6:01am
You can pull a  4 bottom trailer plow all day long , in a parade. Traction booster is half of the set-up for plowing with a WD or 45. You won't have that with a trailer plow.If you're plowin blow sand, it might work if you can keep the tractor from sinking in.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 8:00am
It should pull it,but only 3" deep,lol.
Terry GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry GA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 9:18am
Put a set of loaded duels on the back and a 170 govenor spring in  and it should pull it.Stock imo would be too much for it,but have never tried a 4 with my wd.I use a 2/14 and thats all it wants in tight ground,could not imagine doubling the load.
I couldn't repair your brakes, so I made your horn louder.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 9:39am
On youtube there is a vid of a 45 diesel pulling 4 and walking right along, shined up properly set snap coupler I would say you might have a chance, but 4 on a trailer no way
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 10:08am
Kinda what I figured. The soil is loamy but is in grass for at least 30 years. I'm looking at this thing from 40 yards away but it looks like a plow or two could be dropped off with not much trouble. I dont need to plow a foot deep, 6 inches would be plenty. Plows here are rare as everyone quit plowing during the thirties as all the soil was blowing away. Mostly they end up on peoples front lawns at acreages and farms. this one has rubber tires and will likely sell for $50 bucks. Thanks for the replies, Trev.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 10:10am
That video is my diesel in some nice ground.  Those were the packed headlands though, and it was easier going down the sides as we finished off that field.
I have seen a WD with M&W's pulling a 4-14 fully mounted plow, but not a trailer type plow.  There is a possibility it could do it in nice ground with the traction booster hitch Allis had available for it's trailer plows.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 10:10am
That 45 diesel on YouTube is breaking-in a fresh 10 year long overhaul. It belongs to Ted B. I think he posted on here once that it had more than factory hp too. There is a reason that they video taped it. Some things you just have to see, to believe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 10:13am
Any four bottom plow in reasonably good condition is worth a couple hundred bucks around here.  More if it is not a hydralic lift plow, but has the trip rope type clutch lift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 10:17am
Actually that diesel dynoed 47 PTO HP,
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 10:49am
They said the same thing about a Chevrolet....
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 10:49am
thats  over stock you rebel!!!!!!!!!!!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 10:50am
That was Tom T Hall driving in the TV ads and the back was full of tractor weights to do it
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 10:59am
Back in the late sixties I had a 4 wheel Chevy with a pto and I used it to pull a fertilizer cart and 6 ton of fert. It worked pretty good and rode better and faster than a tractor. Besides that left my tractor still hooked to the plow. It was nice to go to town, get a load, come back and spred.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 11:10am
Can it pull it.  Sure, but all things would have to be perfect from soil type, soil moisture, tractor condition, weights and proper plow set-up.  The general answer is no since rarely would everything be just right.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 11:39am
Late fifties my uncle pulled a three bottom no. 8 Little Genius IHC 16" plow with a Super MTA in third gear. I pulled a two btm #8-16 with a 49 WD in third. Ground was sandy loam to black clay in half mile thru's. He would do fine till he got to the black dirt and then have to drop a gear(TA pulled back) till he got out of it. The WD would hog through it, but would drop a lot of r's. We pretty much ran together, but in a half day he might gain a quarter to a half a pass. In 5 1/3 hours he needed to get gas, cause at 5.5 he would be walking.(been there done that!), while I could run almost another hour and use three quarters of a tank. Short answer to your question, if you can buy it cheap(50-75 bucks) do so, but dont figure on plowing with it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 11:42am
Oh! we ONLY had to put three TA's in that MTA in the 10 years we owned it!
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 1:25pm
I have never plowed with a WD/WD45. But with my limited experience I would say no way. I pulled an Oliver 4240 (3-16s) this past spring behind my JD5400 with loaded tires (probably weights about 9K with loader) in black rich topsoil and even though it did well I wouldn't have wanted an extra bottom. Don't think a WD cold have pulled this 3 bottom let alone a 4.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 2:05pm
Heres the thing about plows and tractors, which I have stated before, but.... every farmer thinks his ground is the toughest plowing SOB they have ever encountered, but 9 times out of 10 it isnt the ground thats so tough its the plow. A plow , anybrand, not set pulls like a stone I can stop a 135hp fwa tractor in its tracks with a 4x and can also pull a 6x with no problem in the same ground. A few years back we bought a 4-16 trailer AC plow a kid that use to hang around here wanted to plow in the field days with our 720 Diesel, so I went to the neighbor farm that had some corn silage taken off of to set the plow so he could go play, I pulled 4-16 in tough conditions and it took a good hr to scour, and set the plow, the neighbor came out to plow with me a 4440 and 4-18 and he was begging and we were plowing the same depth and he was moving slightly faster but not much than the 720. Did the 720 have the power to keep up with a 4440, not hardly the difference was the white plow he was pulling wasnt set properly, but because he had the power he could pull it, the 720 could only pull the 4 x because it was set properly.I pulled 3-16 in 4 lo with a D-17 gas in red loamy clay , it was laboring but it wasnt backing down either, and others on here say you cant hardly pull 3-16 with a d-17, it all in the set up. Just because a plow is in the ground and turning a furrow doesnt mean it is doing it properly.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 2:47pm
Buy it cheap and unbolt 2 bottoms..
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 3:05pm
       I have been wanting to get a four bottom s/c for one of our WDs for some time, I think Ryan is tired of me showing him for sale ads every week. The three bottom just isn.t big enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 3:40pm
Depending on the way the plow is made you cant just unbolt a bottom or two to make it pull easier you will screw up the line of draft and it will not pull correctly
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 3:50pm
I don't know what kind of soil you have, but down here 2-16s is almost too much for my WD. I had a mounted 3-14 a couple years ago and the TB just lifted the tractor off the ground. I don't see any possible way a stock WD would ever handle a 4 bottom. Like Kcgrain said, you won't have much luck dropping bottoms, especially 4 to 2. Find a decent 2-14 trailer plow, fill the tires, and bolt on about 600 lbs of wheel weights and go.
Edited by Bill_MN - 31 Aug 2011 at 3:55pm
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 5:56pm
i have a wd-45 with m&w pistions in it pulled a mounted 4 bottom allis  plow front end was every where but the furrow i bought a wide front and front wheel weights and what a difference it made i could pull in 2nd fine but got the cherry red exhaust even the day time shifted down to low or 1st and i can plow all day in corn stocks.  breaking new ground i dont believe you could.  Nick ia  williams iowa good black soil
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 6:45pm
I have a gas JD 4020. I bought a 4x 18 AC 2000 monobeam. I could plow everywhere on my farm but in the damp black dirt (Okaboji soil type) I couldn't keep the front wheels on the ground. That might have been from the hitch being too high and from having no extra weight on the front of the tractor. But after the front wheels got up to 6 feet off the ground, I quit plowing, took off the front bottom, moved the hitch over and down, added all the weights I had (about 300 pounds) up front, and plowed in 5th gear instead of 3rd where the tractor didn't have the torque to lift the front wheels. Nominally a 93 hp tractor. Didn't ever have a power problem or a traction problem.
I'd think the WD45 might have a chance with 4 12s in the right soil, but not my wet spots and for sure not 4 16s.
Some AC plows (50, 60, 70, 80, and 9000 series) were so modular that you can take the frame of a multiple bottom plow apart and make it one or two bottoms less and it will be just like a factory plow, though the hitch details may make that harder. Those AC frames are bolted up of small pieces to make that economy of manufacture practical.
The traction booster is probably why the WD45 plows better than other tractors of its HP range and a pulled plow won't allow that.
Gerald J.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 7:04pm
What has been done to that WD?!
