OT - Ford ZF-6 speed trans
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Topic: OT - Ford ZF-6 speed trans
    Posted: 30 Aug 2011 at 7:19pm
Off-topic question.
Where do I add fluid to my 2000 F350 ZF-6 speed 2wd manual transmission?  I can't find the fill plug anywhere.  My local Ford service garage can't find it on their website and no one in their shops knows either?  It does not have a dipstick.  Im very puzzled... Thanks for your help
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 7:46pm
Is there not a fill plug on one side or the other?  Its only going to be filled about 1/4 ish of the way up.  Don't look near the top.  You want the fluid to be level with the fill plug.
If memory serves I think it was 1/2 square, but can't remember.  Don't see many manuals anymore, its all lady-matics.
Edited by Roddo - 30 Aug 2011 at 7:47pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 8:03pm
The aluminum 5 speed in my '98 F-150 has hex head filler and drain bolts on the side centered on the aluminum ribs of the casting. Drain at the bottom, filler above it but not directly above it.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 8:15pm
Look at the picture at:
http://cgi.ebay.com/ebaymotors/NEW-FORD-ZF-6-SPEED-TRANSMISSION-7-3L-DIESEL-4WD-2WD-/300594169951?pt=Motors_Car_Truck_Parts_Accessories&hash=item45fccf085f
Isn't the filler plug right to the rear of the filter cover plate there on the middle left side? Looks to be small. Probably drained by pulling the filter cover since this version has an oil pump for cooling.
Gerald J.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 8:59pm
If you dont see it check out http://www.powerstroke.org or google it and links for that page will show up....
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 9:06pm
Looks to be drivers side behind the PTO blank plate.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 9:12pm
and,, if its been a loong time since it has been out plan on it being fused to the case same as welded. Give a try first just in case but plan on it being stuck. The trick to removing them is heat before you strip out the drive socket, not after. Heat it hot but it need not red, let it cool for a couple minutes and it will back out fairly easily IF you got it hot enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 9:48pm
It also uses Mercon 5 auto trans fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 12:38am
Ok, I found the fill plug right where you guys pointed to - Thanks.
Tomorrow, I will heat it to hot, let it cool a few minutes, & then try backing it out.
It has red ATF in it now.  Some people over on powerstroke.org's forum are talking about using full synthetic 10w30 engine oil instead of ATF for longevity.  Anyone on here know differently?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 7:15am
When reading diesel truck forums remember they are heavily populated by people who are into upgraded performance, be it on the street "sled pulling" as they say it, off roading etc. .Read them long enough without the thinking cap working on full power you will be convinced that you need $15,0000 in upgrades just so you can get to church and back without shelling out gear teeth or suspension parts, LOL. I bring this up as often a factory part is just barely good enough to do the job the factory gave it to do and the ZF trannmissions are a good example The rated torque capacities just barely allowed for its usage behind the diesels even before the Powerstroke engine. This is where the dualmass flywheels came into play.  So add a chip, some stage one or two injectors, a bit of sled pulling and stop light drag racing and alchohol assited driving suddenly a part or unit becomes not good enough. Why all this bla bla?  Given some kind of decent treatment and no power upgrades or abuse the average ZF will outlast the rest of the truck with the recomended lubricant in my experiance. I am off the sect that thinks if motor oil is better for the trans why does ZF say run ATF?  Id leave well enough alone.
Edited by Butch(OH) - 31 Aug 2011 at 7:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 6:31pm
Butch(OH), I have to agree with you about getting that same feeling from those truck forums as you mentioned.  But, the notion of switching trans fluids has been discussed on other forums also.  So, I decided to make some calls to transmission repair shops that specialize in this ZF S6-650 transmission to run it by them.
Many of them recommended that I switch to AMSoil full synthetic ATF instead of the original Ford recommendation of regular ATF oil.  Here is weblink from one of them which explains the history of the ZF-6 from Ford to Chevy.  I called them to discuss my options.  Since I do a great deal of trailering with my truck at GVRW of 25,000 - 27,500lbs, they highly recommended that I switch to a full synthetic ATF oil for this transmission under this heavy duty requirement.
While doing a 35mile empty test run (truck only) today, I have already noticed a quieter transmission, smoother shifting, & decreased transmission fluid temperature.  I will post later how it does under load while trailering.
Local Big R Store carried the AMSoil full synthetic ATF @ $11.05/ quart.  The floor manager at the store said they can't keep it on the shelves as its selling that quickly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 6:39pm
Not ALL guys on the Diesel Forums think you have to spend 15k in parts. There are lots of knowledgeable guys there, just like here. Switching to synthetic is never a bad idea....its not reinventing the wheel, just making it last longer. I've found that its the guys on these forums that fix alot of things on a budget. Ford couldn't fix the problems with the 6.0 Powerstroke but the guys on these forums did and what they figured out works well, and for the biggest headache with those trucks isnt super hard, or expensive to fix. There is good and bad with everything. Not being harsh, just standing up for alot of good guys.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
