Model B big end shims. |
joegrgraham
Joined: 12 Nov 2009 Location: Wiltshire, UK Points: 92 |
Topic: Model B big end shims.Posted: 12 Nov 2009 at 4:29pm |
Hi all, I'm in the process of restoring my English B, I've had the crank ground by .20 thou and got all new bearings. I got the mains set up easy enough, but the big ends are very tight, to save me a lot of messing about and trial and error, could anyone be able to tell me what thickness of shims should be needed?
If it seems like a good idea, do it. It's easier to apologise than to get permission.
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 12 Nov 2009 at 5:32pm |
Trial and error while using plastigage is the most common way because of the absents of measuring instruments. You can measure the inside diameter of the main bearings installed in the block before you install the crankshaft. Subtract that from the crankshaft diameter and add .002. That will give you the thickness of shims needed on both sides of the caps. To check to see if filing of the bearing inserts is needed I bolt a insert set in two caps and do the same. They may or may not need filed.
After all the measuring plastigage is still needed to double check your measurements.
The only short cuts that I know of that [works] is to take it to an engine repair shop.
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 12 Nov 2009 at 6:21pm |
When I overhauled my CA (same engine), I had to have my block line bored. When the machine shop did the work, they eliminated the shims altogether. If I remember correctly, the shim packs have 5 layers in them originally.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88637 |
Posted: 12 Nov 2009 at 8:02pm |
factory i think is .006 inch of shims. thats 3 of a .002 shim. if you ground 20 under the factory spec and had 20 under bearings, you might start at .006 shim ?????
Dave Everett
Posted: 13 Nov 2009 at 12:17pm |
Where in wiltshire??
GlenninPA
Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Posted: 13 Nov 2009 at 12:42pm |
you might be neighbors
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 13 Nov 2009 at 1:22pm |
I bolted all caps up without bearings or shims and measured several directions. I then shimmed until the vertical measurement was .001 or so less than what was called for. I then lightly honed the bore, making sure not to go oversize.
joegrgraham
Posted: 13 Nov 2009 at 2:58pm |
Hi Dave, Hows things? was going to email Mark, but I lost his address! BTW, saw the pic of you and the A in T & M, Looks good, bit different to how it was when I came down to get those lift arms. Joe.
Dave Everett
Posted: 13 Nov 2009 at 3:07pm |
Ah gotcha now 07785547048
joegrgraham
Posted: 13 Nov 2009 at 3:22pm |
Cheers Dave, I'll give you a bell.
