hd7g
rjb71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjb71 Quote  Post ReplyReply Direct Link To This Post Topic: hd7g
    Posted: 28 Aug 2011 at 9:58am
Hello, A buddy of mine has a 7g crawler loader that has been sitting for 15 or so years, that he wants to get running. The wiring is a mess, starter solenoid is full of corrosion ect. This has cabling for two batteries, so I believe it originally use 2 - 6volts in series. Any advice on this would be appreciated. Also the turbo is in need of replacement, could anyone suggest a reliable parts source for these machines that will ship to Canada? Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2011 at 11:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjb71 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2011 at 5:43pm
Thanks but all I get is a error message when I click on that link
Lee Bradley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2011 at 6:08pm
I think it is 24 volt system. So two 12 volt batteries.
q4016lanz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2011 at 6:42pm
HI yes one big 12v battarie is all you need the old days they had 2 6v battaries cheers john
15 allis chalmers tractors
9 lanz bulldog tractors
2 water cooled deutz
9 john deeres tractors
14 Aus made orange chamberlains
I spent most of my money on old tractors I wasted the rest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2011 at 6:47pm
look on other HD7 post . < gemdozer  > profile and send a private message , think he can help you with parts and info
the link i had there was to profile but guess the links don't work .
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjb71 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 9:40pm
Yep it is a 24volt system. Got her fired up today, she runs pretty decent. Steel hydraulic line under the battery box is rotten and started to leak. Had to shut her down before I got a chance to move it. So once we get that fixed up, I'll try to move her and see how that works out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 10:13pm
What i have done on steel lines is cut a piece of conduct in half so i end up with piece as long as bad spot + couple inches then braze the piece over the worn area , the brass flows inside the steel patch and creates a good solid repair and also a shield against further wear or rot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjb71 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 5:25pm
The rot is way too long to be able to do that, actually might be able to get away with that on the one that isn't leaking yet. I guess I will see once I get them removed. Thanks for the advice
