LocTite for my AllCrops
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: LocTite for my AllCrops
    Posted: 26 Aug 2011 at 7:38am
Starting to put sheet metal back, will be using bolts instead of rivets in most places.
Worried about vibration losseing things up, wondered if this product would help; any experience?  I like the idea that it still allows dissasembly (supposedly):
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 7:44am
Another option is to use nylon inserted lock nuts but if you already have the hardware then I'd use the Loctite.  Both will work fine.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 7:46am
I would use the red loctite. Blue would work but don't have much holding value.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 7:47am
How hard is it to get the buggers apart if need be?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 7:55am
Somebody will correct me if I'm wrong, I think the blue stuff is good and allows removal with out heat, the red is stronger and the green needs to be heated with a torch to get it apart.
What size bolts will you use to replace the rivets? Will you be using lock nuts or lock washers? A 1/4" bolt with a lock nut will probably stay tight but this would by like a belt with suspenders, you definately would keep things where you wanted them. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 8:02am
Lock washers use will I...Dont want to have to take a torch to get it apart...guess Im leaning blue...
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 9:39am
You wont have to heat the red to get apart and it will hold better than the blue, I would use the red. IMHO
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 9:43am
I am swaying like a reed...LOL!  Anybody ever needed to torch red?
Edited by TomYaz - 26 Aug 2011 at 9:44am
Don M SEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don M SEIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 10:16am
I've used Red and Green ,but on bigger bolts and things on a N6 Gleaner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 10:23am
I see a lot of blue on Ford and GM vehicles. I would agree with Red having more holding power. Maybe on a small bolt you might need to heat Red to get it loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 10:26am
My bolts are 1/4" to 5/8" typically.
hermin's dad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hermin's dad Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 10:33am
I would use red on 1/4 can always snap them off easily no need to heat them
Edited by hermin's dad - 26 Aug 2011 at 10:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 10:34am
I'd use both red and blue, depending whether I ever expected to need to take them apart again.
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 12:10pm
I'd use 2442 (2440?) instead of 242. The 4 digit part numbers have the primer built in. Most bolts are plated and the primer is required to make the loctite bite in. The 3 digit numbers are for plain, steel fasteners.
Blue + primer is what I'd use. Red is aggressive and usually needs at least a propane torch to make them turn loose (heat until smokes). Green is "wicking" grade. You use it after assembly and it wicks into the threads. It will come apart w/o heat like blue.
Purple = light
Blue and Green = medium
Red = aggressive, heavy
CT
2014 LS P7010C, 1962 Farmall 504 Diesel (1st tractor) w/ 2008 Koyker 220 FEL, 1968 Allis Chalmers 180 Diesel, Komatsu PC38UU-2 Excavator, Various attachments for all!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 1:54pm
I have used all kinds of it in the past 20 years for different things. I would lean toward the red also. You can get bolts apart with a wrench after the red sets up. Green, we used for cylindrical part bonding where a torch is needed to disassemble. There are different green products also. Some are gap filling up to .015 of an inch per side. If the bolts are plated, blue probably wont do any better than a lock washer. Both surfaces should be cleaned with brake clean or some type of solvent so the loctite can work also. We used green 680 for pinning bronze bearings and the heat of a drill bit will sometimes soften it enough to pull old pins.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 2:16pm
Bolts smaller than 1/4 use purple 222ms, On bolts 1/4 and over for medium strength, use blue242 (or as mentioned before the one with the primer) On bolts 5/8 and over use red 262. This info is from a Loctite selector chart i've had in my desk for years . Thanks Tom for giving me a good reason to use it. Hope this helps. I think with any one you use you will want to check them after you use the combine for a while. Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 2:30pm
I think I'd do like Hermin says. Red is plenty strong. Unless there was a threaded hole where you can't get to the back side, I'd be inclined to do it that way. Red is what Ford uses on cab bolts. Makes it real fun sometimes to get them out when removing a cab...
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 3:29pm
Stick to the blue, and make sure your parts are CLEAN and use primer, red is very aggressive to the point that when used with the primer on larger fasteners (over 2" diameter) assembly cannot be facilitated before it sets, and it WILL need heat and lots of it to get it apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 10:06pm
If they are bolts with nuts use red, you can always twist them off. If they screw into something other than a nut you might want blue althow red will come out most of the time with out heat.   MACK
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2011 at 11:22pm
I understand the idea of being able to dissasemble( how often is that ever needed?) but the best thing about rivets is they fill the hole tightly along with clamping force which keeps things from moving.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2011 at 7:50am
I agree with Mack.   Use red so they don't come apart and if they need to be dissassembled at a later time, bolts that small, the red will either come apart or they will snap off with an impact.  Either way you won't have to worry about them coming loose from vibration and wrecking something in the meantime.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2011 at 12:24pm
Just wring them off if you need to take it apart!
