13.6x38 Tire Pressure
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: 13.6x38 Tire Pressure
    Posted: 25 Aug 2011 at 9:20pm
What tire pressure should I run these tires at for pulling. They are both 6 ply. One is a Firestone F151 and the other one is a Titan power king. They have about 95% tread.
Brian
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 4:43am
6 to  8 psi. Should get you good bite.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 5:24am
In hard tracks you need 10 lbs or so and in loose, sandy, tracks maybe 6 to 8lbs. The lower the pressure the more the lugs want to turn under and the lower the drawbar gets.
This page was generated in 0.234 seconds.
